Collector Gaskets - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 6th, 03, 01:23 AM Thread Starter
Kevin
Is there any real good way to seal collectors. My headers have flat gasket surfaces and three hole flanges. I've tryed fiber and copper. Tryed mating the gasket surfaces. Even made inserts for between the collectors and exhaust pipes. Nothing has worked very well yet. No matter what I've done, they still have small leaks all around the area. Finally got paint to stick to the pipes, so really don't want to pull them off again. Thanks, Rhat
KRhat is offline
post #2 of 7 (permalink) Old Aug 6th, 03, 06:30 AM
Vintage 68's Avatar
Rhat;
I usually take my grinder and make the flange areas as flat as possible. I use the Mr. Gasket Copper Flange gaskets, they do leak a little sometimes at first, but the carbon seems to seal the leaks after a while.
I have used Header Wrap from Summit (http://store.summitracing.com/defaul...rt=header+wrap) and others to get that final little bit of seal and make the system nice and quiet. This is an under $50.oo sollution and you wouldn't have to take the system apart again. Wrapping them on the car though is a real PAIN [img]graemlins/angry.gif[/img] sometimes.
A good job of header wrapping brings the primary exhaust noise level back down to almost the cast manifold level.
Hope this helps.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 7 (permalink) Old Aug 6th, 03, 01:26 PM
I saw a thing on horsepower TV and have yet to find it again. It was a clamp comprised of 6 pieces, made of aluminum, and assembled to create a triagular shape. It provided plenty of surface area between the three bolts, looked good, and wasn't that expensive. But I've searched the HP TV website and other places looking for them and have come up empty handed. If I ever find out where to get them, I'm going to buy a set.
-dnult
dnult is offline
post #4 of 7 (permalink) Old Aug 6th, 03, 04:48 PM
Bruno
Lightbulb
Maybe covering the gaskets with high temp RTV silicone, like sometimes needs to be done on the cylinder head header's flanges? You can clean around the flange as soon as you tighten the bolts, when it's easier to remove any excess of RTV sealant.
"Our affair with Camaros is a life sentence without the possibility of parole".
ORENCH is offline
post #5 of 7 (permalink) Old Aug 6th, 03, 05:46 PM
Unhappy
dnult I saw that episode also and for the life of me I can't remember who made them nor can I find them on the internet. Looked like a great solution and I'd like to try a set myself.
Donald
68 Camaro convertible (resto on hold)
MytMini is offline
post #6 of 7 (permalink) Old Aug 6th, 03, 07:19 PM
cut them out of there and replace them with ball flanges, or braided flexpipe and a 2 bolt flat welded flange.
if you ever get a header 3 bolt flange to seal up, murphy's law dictates you will then bottom out and destroy it before you can convince others that you sealed it successfully.
ohcscott is offline
post #7 of 7 (permalink) Old Aug 6th, 03, 07:28 PM
cut them out of there and replace them with ball flanges, or flexpipe and a 2 bolt flat welded flange.
ohcscott is offline
