BRAKE PROBLEM -PROP VALVE - Team Camaro Tech
post #1 of 4 (permalink) Old Mar 28th, 02, 06:35 PM Thread Starter
I have a 1969 Camaro with converted disc brakes from 1972 Nova. Each time you oush the brake the left caliper locks up until you push the reset button on Prop-Valve. I have replaced the caliper,M/C, hose, and prop valve. Any thoughts?
KWardlaw is offline
post #2 of 4 (permalink) Old Mar 29th, 02, 01:50 AM
Rodney
when you bleed brakes are you getting strong pressure out of other 3 wheels
z10rod is offline
post #3 of 4 (permalink) Old Mar 29th, 02, 05:54 AM
Matt Jones
The 'reset button' is not a reset button. It is the metering valve plunger. When a certain amount of pressure exceeds the capabilities of the internal spring, pressure to the front brakes will be applied. In other words, it's the 'hold off' valve.
You will get much more information on this in the Brakes and Suspension area.
Are you sure you hooked up the lines in the correct manner? They are not the same as the '67-9 proportioning valve.
1969 Base Camaro
Vortec 350, Perf. RPM, Demon Carb., TH-400
All sheetmetal is NOS GM
http://www.geocities.com/compuboy007/
Silver69Camaro is offline
post #4 of 4 (permalink) Old Mar 29th, 02, 12:31 PM Thread Starter
Everything appears to hooked up correctly. Someone suggested that the valve in the front of the M/C might be the problem. I will check that out first. Thanks for your help.
KWardlaw is offline
