mini starter shims - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 19th, 01, 05:37 AM Thread Starter
Need a litle help with proper shimming of a mini starter.
Starter cog will not engage the flwheel unless I pull it out with a screwdriver, it will then stay in the gear. The battery is new & charged to the max before I attempt to start the engine.
I have installed 2 shims between the block and the starter bolt holes that drops the starter down from the block; without any change. When I pull out the cog , it will stay in the flywheel gear and I can just slide a paperclip between the two.
I need suggestions for the placement of the shims? Thanks, Dan
'68 396 +.60 TH400 12 Bolt 4:10 Deluxe Interior
Dan Smart is offline
post #2 of 2 (permalink) Old Oct 19th, 01, 10:26 AM
Paul
PDQUICK's Avatar
For somne reason, the solenoid on your mini starter is not working right! It requires a lot more power to engage the starter drive than it does to hold it engaged. Either you have a really weak signal to the solenoid, or the starter is broken.
Check the big violet colored start lead to the starter. Make sure there is plenty of current available to the solenoid. The wire could be frayed half way through, or there could be a green (dirty) connection at the firewall, or you could have a tired ignitoin switch contact. All of these things should be ruled out before you condemn the starter.
Use a test light at the starter, not a voltmeter! You need to draw a lot of current through the wire to make sure there isn't a high resistance somewhere.
MightyMice
PDQUICK is offline
