vacuum line placement - Team Camaro Tech
post #1 of 2 (permalink) Old May 24th, 01, 12:11 PM Thread Starter
Kinda new to this stuff, any help greatful.
I have a 1980 trans am, but i put a chevy 355 in place of the 301. I'm running a edelbrock 3701 intake, 9635 carter 625 electric choke carb, stock heads, headers, 3 inch flowmaster exhaust and a stock RV cam ( .420 lift intake &.443 lift exhaust, duration is 204 degrees at .050 lift intake & 214 degrees at.050 lift exhaust). Auto trans and stock converter. I never got a diagram on how to install the vacuum lines on the carter carb. It would have been easy if I was just replacing the carb, but I scraped all the pontiac stuff for chevy. could any one help me with the proper method of connecting the vacuum lines?(egr,pcv, brake,dist, etc) The motor runs like it has a vacuum leak. Also, is a 3 inch exhaust too much for my application?
Thanks to all. Looks like an awesome site for chevy owners!
reedld is offline
post #2 of 2 (permalink) Old May 24th, 01, 01:56 PM
ZZ_430's Avatar
The Carter is identical to the Edelbrock. Tech line # is 1-800-416-8628 They will be able to help you. Good luck! http://hometown.aol.com/zz430droptop67rs/
ZZ_430 is offline
