electric-slow & low - Team Camaro Tech
post #1 of 2 (permalink) Old Mar 31st, 03, 03:47 AM Thread Starter
robert
rolling-robert's Avatar
Lightbulb
i have a problem with my 1982 camaro, 350 v8 1978
all my electric stuff works slow [img]graemlins/boring.gif[/img] , power windows, headlights, turnsignals, even when i start the car it cranks very slow.
my voltage meter gives 13 and above when driving, i replaced the altenator and battery.
when i connect the positive cable to the battery first and then the ground cable it sparks, viceversa same thing...
u know what the prob is here?
thanks [img]graemlins/thumbsup.gif[/img]
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
post #2 of 2 (permalink) Old Mar 31st, 03, 05:00 PM
When the engine is cold chase down the short so you wont cut yourself short chasing it. Clean around allot of your contacts in case you are grounding out a power line from wet fluids like down at the starter wires or other places. There are the relays that might be all gunked up also and bleeding power. If you don't have a multi meter now would be a good time to get at least a cheap on. Don't read resistance when power might be on a line. Pop!
Snatchin'gears is offline
