GASOLINE SMELL - Team Camaro Tech
post #1 of 4 (permalink) Old Jan 16th, 01, 11:09 PM Thread Starter
Sometimes after I pull into the garage and get out of my car there is a strong smell of gasoline. It also seems to blow through my vents when I use my a.c. but not when I use the heater. I have a 1990 Camaro RS. It does not happen all the time, but seems to happen more when the weather is warm.
LAYDBAAK is offline
post #2 of 4 (permalink) Old Jan 17th, 01, 02:52 AM
Fire estinguisher handy? You'd better get under the hood and look for obvious signs of a gas leak. If you can't see anything obvious, just light a match and........ scratch that. Get it looked at ASAP by a professional. Car fires are no bueno. I'm not joking about the fire estinguisher. Everyone should have one.
kz1000ltd is offline
post #3 of 4 (permalink) Old Jan 17th, 01, 10:30 AM
better check your car on http://carpoint.msn.com
there was a recall on 1990-1992 camaros and firebirds for a gas tank filler neck problem, this could be it if your car was not completed.
Chris's 67 RS can be seen at http://www.67rs.com
JOIN THE CAMARO NET WEBRING! http://nav.webring.yahoo.com/hub?ring=camaronet&list
[This message has been edited by Chris Edwards (edited 01-17-2001).]
Chris Edwards is offline
post #4 of 4 (permalink) Old Jan 23rd, 01, 02:24 PM Thread Starter
thanks fellas. had to replace charcoal filter canister and bad valve.
LAYDBAAK is offline
