speedometer gear info. - Team Camaro Tech
post #1 of 4 (permalink) Old Aug 22nd, 02, 05:13 AM Thread Starter
I need some info on the gear that is on the tail shaft in my old buggy. I have a 74 camaro with a 73 motor(350) and tranny(350. Not sure about the rear end but I would guess it to be a stock 3.23. Speedo quit and I pulled the tail shaft housing. the gear that is on the tail shaft moves around pretty easily. I put it back in place and hooked everything back together and it worked for about a mile or 2 and then no more. Does that gear have a clip that it needs to hook onto the tail shaft or is it supposed to be able to slide around some. I would guess a part is broken on it but I cant find any diagram or info on this to try to figure it out on my own.
gateruner is offline
post #2 of 4 (permalink) Old Aug 22nd, 02, 06:30 AM
JohnZ's Avatar
There should be a spring steel clip that locates and retains it on the output shaft.
JohnZ
CRG
'69 Z28 Fathom Green
[This message has been edited by JohnZ (edited 08-22-2002).]
JohnZ is offline
post #3 of 4 (permalink) Old Aug 22nd, 02, 09:49 AM Thread Starter
Well, looks like I am pulling that puppy apart again. Thanks for the answer.
post #4 of 4 (permalink) Old Aug 22nd, 02, 06:06 PM
If you go to the G.M. dealer they should have picks on the screen at the parts counter. If you know anyone at a tranny shop they should have a clip. I think once you see the part you will see how it fits.
Larry
www.lnjstreetrods.com
lnjstreetrods is offline
