tpi idle problem - Team Camaro Tech
post #1 of 15 (permalink) Old May 2nd, 01, 07:19 AM Thread Starter
Cool
hello,I'm elfiero from mpls and I am new here
and think this is a great forum!I have a '89
305TPI with a manual trans.My problem is this
it won't idle correctly-most of the time it
idles way too fast(1200-1500)then all of a
sudden,it trys to idle down to about 500RPM
and surges or dies!It has no stored codes or
check engine light-also,the fuel milage is
bad(10-12MPG)I have replaced the following:
TPS,IAC,coolant sensor,O2 sensor,all vacuum
hoses,EGR valve,cold start injector,plugs,
wires,complete distributor,EST module,ECM,
fuel pressure reg.Now I am out of ideas and
would appreciate any help you might give me
thanks for your time!!!
elfiero is offline
post #2 of 15 (permalink) Old May 2nd, 01, 08:55 AM
If you have a bad MAF sensor it could do that. Try tapping it lightly also look inside to make sure the thin wire is still intact in the center part..
Also it may sound dumb but try disconnecting the battery for 30 seconds and then hooking it back up.
6-71BlownCamaro is offline
post #3 of 15 (permalink) Old May 2nd, 01, 09:03 AM Thread Starter
Cool
Forgot to mention I tried 2 MAF sensors and
replaced all the intake manifold gaskets!
elfiero is offline
post #4 of 15 (permalink) Old May 2nd, 01, 01:18 PM
With no codes stored, this could be difficult to narrow down. You might try cleaning the throttle body and IAC pintle. Typically, they get dirty, causing an erratic idle, surging, and dying due to its inability to smoothly control the incoming air flow. Also, make sure your TPS is working correctly, and that it is carefully adjusted to .45 volts at idle. Try these things first, then let me know what you find. Ray
RABarrett is offline
post #5 of 15 (permalink) Old May 2nd, 01, 03:34 PM
i dont know on tpi v8's but on my v6 it used to idle around 3000 rpms come to find out my idle air control valve was stuck shut. replaced it and idles fine now. it screws into the front of the manifold and controls the amount of vacuum that goes through a main line using a pintle thats screws in or out. Mine had 4 wires on should be to hard to fine was about 40 bucks
audioxellence is offline
post #6 of 15 (permalink) Old May 2nd, 01, 04:55 PM
What blown said makes alot of sense, it will clear any codes if any, also this may sound dumb but is the bulb good in the check engine?
I don't know just a suggestion pretty hard to diagnose with no codes, but you already know that.
86z28 is offline
post #7 of 15 (permalink) Old May 2nd, 01, 04:56 PM
Prowling the Streets for rustangs
86z28 is offline
post #8 of 15 (permalink) Old May 3rd, 01, 03:24 AM Thread Starter
I appreciate the info guys,I have already
cleaned out the throttle body and the check engine light does work.I guess I'll have to
take it over to TPIS in chaska,I know some-
one who works there.I'll let you know what
they find.
elfiero is offline
post #9 of 15 (permalink) Old May 3rd, 01, 04:41 AM
Hello there,
Here is a suggestion, my brothers 1986 Trans Am with a 305 was ideling arraticaly, so I took off the throtle positioning sensor, and the idel air control valve and cleaed them using electronics cleaner. After they dried I put them back in and it has been idleing fine ever since. (The idle air control valve had alot of carbon build on the spring and I think that is what was causing the weird idel). Just make sure to mark the position of the throtle positioning sensor because if you don't put it back in exactly the same spot it will mess your idel up. Also only use electronics cleaner, as carb. cleaner will damage the electronics. Hope that helps and good luck.
Sincerely
Dave Valentino
dave313131 is offline
post #10 of 15 (permalink) Old May 3rd, 01, 07:05 AM
I have had problems with bad connectors. Try jiggling the connector at the sensors, and ignition module and see if one has an intermittant problem.
TTFN
Mat
Mat Klemp is offline
post #11 of 15 (permalink) Old May 3rd, 01, 02:14 PM
I had a similar problem with mine that turned out to be two problems. First was the fuel injectors - had them tested by the guys at www.cruzinperformance.com and all 8 of them were leaking like seives. At idle, they would "drip" more fuel than needed and cause the idle to bounce.
Second problem I had it looks like you've already eliminated - the IAC valve. Like others have said here, cleaning it really helps and it took care of my high idle.
miroc89 is offline
post #12 of 15 (permalink) Old May 3rd, 01, 06:12 PM
elfiero (fiero with a bed? )
I had an almost identical problem when I installed a TPI motor in my el camino. Turned out that I had a massive vacumn leak at the base of the intake manifold. New gaskets & torquing it right made things much better.
There was a thread on tracking down vacumn leaks in one of the Team Camaro forums within the last week. Do a search and it should turn up.
Rick Schaefer
68 Camaro
72 El Camino
TPI350/700r4
rick is offline
post #13 of 15 (permalink) Old May 5th, 01, 06:33 PM
David Pozzi
davidpozzi's Avatar
Make sure you adjust the throttle position sensor to achieve the proper voltage signal, open and closed.
If it's mis adjusted, it will cause erratic running.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
65 Lola T-70 Chev 350
Can Am Vintage Racer
davidpozzi is offline
post #14 of 15 (permalink) Old May 6th, 01, 09:04 AM
I have to agree with miroc89. Mine also had the same problem you are having. Turns out, just as he suggested, the injectors were leaking and/or the coils were burning up. I replaced all my injectors and no problems since. Definately give Rich a call at Cruzin!!
cardude is offline
post #15 of 15 (permalink) Old May 6th, 01, 01:44 PM Thread Starter
Cool
Thank you for all the good ideas!I'll try
resetting the TPS next.I have had all the
injectors flowed and checked for leaks and,
I have replaced all the intake gaskets.I'll
just keep try'in stuff till I stumble on the
problem!!
elfiero is offline
