MSD 6al cutting out - Team Camaro Tech
post #1 of 2 (permalink) Old May 2nd, 03, 08:27 PM Thread Starter
I've had the 6al box in my '67 for a few years. Just recently, I've started having problems.
A few days ago, when I tried to start the thing, the starter just spins and there's no ignition. I got out my test light, turned the key to the on position, and there's no fire at the coil. A few days later I went out and checked for fire at the coil, and there was. Then it started right up. So I drove around for 20 minutes or so, and it died. Got out the test light, and again there's no fire at the coil.
So right now I'm thinking there's a loose connection in the box, possibly caused by corrosion due to condensation?
Before I pull it apart and look at it, I'd like to get some feedback from anyone who might have had this problem.
ryskey67 is offline
post #2 of 2 (permalink) Old May 3rd, 03, 01:59 AM
My 6AL box did that just prior to it dying. I went to MSD's website and tried their method of checking it and it showed the box was dead. I called them and confirmed this, and they told me I could send it in to them and they would rebuild it for not more than like $95 (I think was the amt), so I sent it in. In less than 2 wks it came back for much less than the max, about $55, good as new.
They told me a resistor or diode along with another wire, had shorted out.
It was actually a quick, reasonably priced fix if you ask me.
ztoy is offline
