No fuel to carb - Team Camaro Tech
post #1 of 6 (permalink) Old Sep 11th, 02, 05:33 AM Thread Starter
After installing a new fuel tank, sending unit and fuel pump I cannot get fuel to the carb. I can fill the bowl and it runs fine. How long does it take to get it pumping fuel? I put about 4 gallons of fuel in the tank. Anyone have any suggestions?
This is a fresh 350 in a 69.
thanks
Bruce68 is offline
post #2 of 6 (permalink) Old Sep 11th, 02, 05:47 AM
Not trying to be a "wiseguy" but is the rod for the fuel pump lever in the motor?
I put a new tank and sending unit in my car six months ago and it pulled right up to the carb. with no problem.
Drew
drew69 is offline
post #3 of 6 (permalink) Old Sep 11th, 02, 05:59 AM Thread Starter
Not a wiseguy question. I've actually done that before. I did double check though and it's there. I guess I'll try another pump since I pulled it to check for the rod.
Just wondering if there's anything I should have done to the sending unit prior to assembly?
Bruce68 is offline
post #4 of 6 (permalink) Old Sep 11th, 02, 04:11 PM
Bruce, I didn't do anything to the one I used which was a repo and I did step it up to the 3/8" line. It already had the sock attached so I just bolted it in. I also only put in about 4 gallons of gas until I drove it to the gas station.
Let us know what you find.
Drew
drew69 is offline
post #5 of 6 (permalink) Old Sep 12th, 02, 04:42 AM Thread Starter
Got it! The only part that's not new is the hard line from the tank to the pump. I shot air through it when it was removed about two months ago and it was clear. I guess I should have blown it out again just before I connected the hoses.
It's pumping fuel like it should now.
Thanks for the replies!
Bruce
Bruce68 is offline
post #6 of 6 (permalink) Old Sep 15th, 02, 03:17 AM
Bruce,
Great !
Drew
drew69 is offline
