86 ,camaro..gauges wont work when dashlights are on - Team Camaro Tech
post #1 of 2 (permalink) Old Oct 15th, 02, 01:36 AM Thread Starter
pb
i've got a 86 camaro...2.8(sniff!!)when the dashlights are on,the gauges don't work right and the right turn indicator glows, also...the tach seems too high. this is a restoration project,so i'm not sure if this is original cluster for car. all bulbs inside and out have been replaced, no blown fuses...thanks for any help...PB
pb is offline
post #2 of 2 (permalink) Old Oct 15th, 02, 12:56 PM
Definitely sounds like a ground problem. With the lights off the gauges use the dash lights as a path to ground.
'69 RS Camaro
355 5-speed 4.11
1 2RUN is offline
