no idle after 4150 rebuild - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 15th, 02, 04:57 AM Thread Starter
peter
just rebuilt my 4150 650cfm. basiclly cleaned, and replaced all gaskets.
fired up the car, and i can't get it to idle.
just wondering if maybe the floats were set too low it would cause this? (fuel level was 1/8" below the sight holes.)
spooge is offline
post #2 of 6 (permalink) Old Jul 15th, 02, 05:14 AM
DjD
DjD's Avatar
Float level should be set so bumping the fender causes a dribble but running, nothing spills out. Do your idle mixture screws effect a change when you open or close them?
...Dennis
"The '69, the '96 & the club"
DjD is offline
post #3 of 6 (permalink) Old Jul 15th, 02, 06:52 AM Thread Starter
peter
I screw'd them out 3-4 turns with no result.
spooge is offline
post #4 of 6 (permalink) Old Jul 15th, 02, 09:17 AM
Spooge,
Check your gasket between the baseplate and the main body. The holley rebuild kits come with several ones. One will work and the other will block the idle feed holes. I know this from experience. The gasket should have a hole for every hole in the baseplate and body that connect through the gasket.
Kent
67 SS 427
kwissman is offline
post #5 of 6 (permalink) Old Jul 15th, 02, 12:55 PM Thread Starter
peter
i was thinkin the same thing, but wasn't sure if the gasket would cause the problem. i found the original, and one of the leftovers from the kit, that match'd. looks like i used the wrong gasket.
i'll post results later inm the week, sincee i keep the car 30miles away from home, and i have lots a work.
Thanks for the replies/help !
spooge is offline
post #6 of 6 (permalink) Old Oct 8th, 05, 04:40 AM Thread Starter
peter
Re: no idle after 4150 rebuild
sorry for the Very late response
It was the wrong gasket
Was a drinker back then
__________
'67, rs/ss
spooge is offline
