Autometer Fuel gauge - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 31st, 01, 10:21 PM Thread Starter
my fuel gauge is acting wierd, it shows full all the time but now and the int fluctuates. how can i bench test the gauge?
David R is offline
post #2 of 5 (permalink) Old Feb 1st, 01, 06:46 AM
It sounds like there may be a ground problem somewhere. Check the ground lead to the guage and the one near the tank. What year is your car? Check out this link. It was explained well by Mark C.
https://www.camaros.net/forum/Forum10/HTML/000275.html
[This message has been edited by Mike67RS (edited 02-01-2001).]
Mike67RS is offline
post #3 of 5 (permalink) Old Feb 1st, 01, 07:35 AM Thread Starter
67 convertible
David R is offline
post #4 of 5 (permalink) Old Feb 1st, 01, 08:07 AM
If you detach the lead that goes to the sending unit through the trunk floor, your guage should go to empty. It is located just in front of the filler neck inside trunk. If it does, that will at least tell you your needle works. I'm no electrician, just speaking of experience with mine. On mine, it was the ground near the right front of the tank.
Mike67RS is offline
post #5 of 5 (permalink) Old Feb 3rd, 01, 07:59 PM
Thomas
Cool
Had the same problem with my Sport-comp gauge. Make sure you are well grounded and you have a good connection to your sending unit and you should be fine.
70 1/2 RS Camaro
Slomaro is offline
