can't shift gears - Team Camaro Tech
post #1 of 8 (permalink) Old May 1st, 01, 05:16 PM Thread Starter
91z28
I took my 1991 z28 camaro manual transmission,to the shop to change 4 fuel injectors and some work on the computer, and air fans. When I when for the car the gears where very hard to shift I have to clue what could be the program I knew I needed some work on the shift pedal put it still work fine, but now it's very hard to change shift's the harders is the first shift can any one help me?? Thanks for your help guys.
Ivan is offline
post #2 of 8 (permalink) Old May 1st, 01, 05:36 PM
Most likely a pilot bearing,If it shifts normal with the engine off.Didnt understand all of your problem.If this is your symptom check it soon,because a bad pilot bearing can damage the transmission input shaft.
69 Camaro SS 350 4 speed
55 Belair Sedan Pro Street 355 auto 9''
gene stills is offline
post #3 of 8 (permalink) Old May 2nd, 01, 09:43 AM Thread Starter
91z28
I try what you said and you where right it shiflt normal when the engine is off, but this morning after playing with the gears with the engine off, when I turned the engine on the gears where working good again, until I when to a gas station and turn the engine off, when I try to change gears it was hard, what would be the problem?
Ivan is offline
post #4 of 8 (permalink) Old May 2nd, 01, 12:54 PM
With a pilot bearing,if its just starting to go it wont bind all the time,What the bearing does is allows the trans input shaft support at the front,sets in the flywheel,and turns at the same rate as the flywheel until the clutch is depressed then the bearing allow the input shaft to slow or stop allowing gear shift change.Also i forgot to ask about the clutch. Does it dissenguage properly.This can cause the same problem.Check to see if when its pushed to the floor and in gear it doesn,t start to pull untill your petal is at least 2 t0 3 inches off the floor
post #5 of 8 (permalink) Old May 3rd, 01, 09:32 AM Thread Starter
91z28
Thanks for the reply, the pedal is working find,I'm going to take it to the shop and see, do you know in what price range is changing the pilot bearing is, I just invested $1300 on the car in order to pass emmission. Thanks again.
Ivan is offline
post #6 of 8 (permalink) Old May 3rd, 01, 06:46 PM
Dale
200$ ish.
68 z28 ,68 rs 327 ,73 454 vette, 2 goofy kids
dale68z is offline
post #7 of 8 (permalink) Old May 4th, 01, 07:34 AM
Try ajusting the cluch a little bet it may be off a little.If it is letting the trans trun it will make it hard to shift.
TIM
Tim Meredith is offline
post #8 of 8 (permalink) Old May 4th, 01, 06:56 PM
I agree with Dale,around $200.00 labor and part $10.00 would be fair.Also have your clutch pressure plate & bearing checked.If it needs it now would be the time to do it since your already there. GENE
