1986 z28 cannot get fuel pump to work - Team Camaro Tech
post #1 of 5 (permalink) Old Dec 16th, 00, 05:40 AM Thread Starter
replaced fuel relay but still nopower to pump is there any way to check pump?
aquagraf is offline
post #2 of 5 (permalink) Old Dec 17th, 00, 06:14 AM
Freddie
Have you unhooked the wires at the fuel pump and checked for voltage with a digital volt meter?
big gear head is offline
post #3 of 5 (permalink) Old Dec 17th, 00, 04:06 PM
Did you check the fuse on the front of the right shock tower?
Leo Paugh
MCC #017
www.clark.net/pub/chevelle/mcc.htm
There are no strangers here, only friends you haven't met.
chev64 is offline
post #4 of 5 (permalink) Old Dec 18th, 00, 01:01 PM
ok you can run 12Vs from the battary and that will tell you if its bad you want to jump the is not in the gastank right do that and that should tell you right away and its easy
james is offline
post #5 of 5 (permalink) Old Dec 19th, 00, 05:08 PM
David Pozzi
davidpozzi's Avatar
When you turn the ignition to ON the fuel pump will run for only 3 seconds then stop.
Make sure you aren't getting fooled, it won't run all the time.
Until the oil pressure switch kicks in.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
[This message has been edited by davidpozzi (edited 12-19-2000).]
davidpozzi is offline
