2 cars, 3 problems - Team Camaro Tech
post #1 of 2 (permalink) Old Nov 30th, 01, 06:11 AM Thread Starter
where is the best place to start troubleshooting "missing"? I noticed the car really lost some power then shortly thereafter began to run like a 3 legged horse. On a BBC, I've installed a scattershield and occasionally when starting the car it will make a loud 'bang' noise. Doesn't happen all the time. Also changed to steeper gears, I noticed the temp went up at @15 degrees. It will not start after driving for at least 20min. It'll start after sitting for a bit. Hot start problem?
ErikSOCAL is offline
post #2 of 2 (permalink) Old Dec 1st, 01, 08:09 PM
Talking
If your car was running great and then lost power and started running poorly acting like it is missing, with the equipment that you say you have instlled I would assume that this engine (BBC) saw some rpms and I would start with checking the valvetrain (valves, rockers, rushrods). The symptoms sound all too familiar.
VINTAGE CAMARO is offline
