flooding out - Team Camaro Tech
post #1 of 7 (permalink) Old Oct 14th, 01, 05:22 AM Thread Starter
I have a 90 model camaro rs with a 3.1 liter engine... its getting way to much gas and flooding out the plugs and missing....it did run good but had a leaking injector...so i took the upper plenum off and put an o-ring on the injector . out it back together and now it gets way to much gas.... and i have tried everything... please help...thanks
wildride21 is offline
post #2 of 7 (permalink) Old Oct 14th, 01, 08:31 AM
have you checked the fuel pressure?
if its high then youve got a bad pressure regulater. but i think youve probably got a vacum leak at the upper plenum or fuel rail.
chris
1980 Z/28
350 .60 over stock bottom end world products torker2s 280H compcam edel.performer rpm,holly 750 dual feed.
2200 stall,- but still not done.
[This message has been edited by the mechanic (edited 10-14-2001).]
the mechanic is offline
post #3 of 7 (permalink) Old Oct 14th, 01, 04:02 PM Thread Starter
<BLOCKQUOTE>quote:</font><HR>Originally posted by the mechanic:
<HR></BLOCKQUOTE>
actually i did check the fuel pressure and it was right at 40 psi....ive also checked the MAP sensor,computer,TPS sensor and a few others...but im wondering about the timing...i had the distibuter out of the car and i might not have dropped it in just right...cause i found some lititure on it and i have my number one plug wire in the wrong spot..but i did drop it in to where the rotor button is right on the no.1 wire but ist still on the wrong spot on the cap...could that maybe cause it? Thanks a bunch
post #4 of 7 (permalink) Old Oct 14th, 01, 06:01 PM
yes-yor timing needs to be for sure dead on before even thinking about other possibilities. let us know how it goes.
chris
1980 Z/28
post #5 of 7 (permalink) Old Oct 15th, 01, 02:57 PM Thread Starter
Thumbs up
well i redid my timing and i got it running pretty good...but while it is idleing it has a slight miss and runs a little rich.. but when i drivwe itr around the parking lot a few times and get out and check the exaust its not rich then until i let it idle for about a minute then begins to get rich...because it doesnt miss at a higher rpm like when im driving it....i havnt tried spraying carb cleaner or anything around the injectors to see if i have a leak yet or not...will try that tommorrow...kinda wondering if the injector i replace uisnt wrong also...but hey its getting closer....thanks again for trying to help me get this problem solved
post #6 of 7 (permalink) Old Oct 15th, 01, 04:24 PM
no problem, hows it idle,rpm wise?
chris
1980 Z/28
post #7 of 7 (permalink) Old Oct 16th, 01, 03:40 PM Thread Starter
well i discovered today that it runs real rough at adle and high rpm's until it warms up...then it starts to run better...but it idles about 9000 after the engine is warmed and about 12 to 14 when cold....but there were no leaks around the injectors...but still misses at idle.. but not as bad at higher rpm....also put new temp sensor for the computer in...and still no good...see the car was like this when ui bought it...thats why i dont know much about it...the odometer shows only 92,000 miles but then again the speedo dont work and its hard to tell how long ago it quit...thanks again........James
