runnin rough - Team Camaro Tech
post #1 of 3 (permalink) Old Jul 10th, 03, 12:41 PM Thread Starter
i have an 86 camaro v6 2.8 milti port fi
it has set for 4 months now it wont run right ive put a fuel pump in it a coil an inline filter i cleaned the injectors an it still cuts out an misses really badwhen i first start it it will run good 4 a few seconds then it starts cuttin out when i try 2 give it gas any ideas whats wrong with it
camaro kid 19 is offline
post #2 of 3 (permalink) Old Jul 10th, 03, 05:15 PM
What about plugs, cap, rotor, and wires? If they aren't brand new, I'd recommend replacing them -- basic engine tune up stuff.
Is it a MAP or MAF system? In ether case the MAP / MAF sensor could be bad. But if you get a decent service manual, there should be troubleshooting procedures for sensors. It's a good idea to follow them, because those can be expensive parts to throw at a problem.
-dnult
dnult is offline
post #3 of 3 (permalink) Old Jul 11th, 03, 04:42 PM
i have the 86 camaro service manual if you know what part you need. email me at [email protected] because i may forget to check back with this post
shane_c2003 is offline
