454 no oil pressure NEW TWIST - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 29th, 01, 06:55 PM Thread Starter
THANK YOU FOR ALL THE REPLYS FROM MY ORIGINAL QUESTION .I HAVE A NEW TWIST,,,OK MY TEMPERATURE GAUGE WAS INCORRECT AND BECAUSE OF A HOLE IN MY RADIATOR THE TEMPERATURE WAS GOING OVER 215.ADD THAT TO THE FACT THAT I DID NOT HOOK THE STOCK OIL COOLER WHEN I INSTALLED THE MOTOR.IS THERE SOME TYPE OF REGULATOR IN THE OIL COOLER PLATE MABY?WITH THE TEMPERATURE AT APPROX 180 THE MOTOR MAINTAINS 10 TO 15 LBS OF OIL PRESSURE.BUT AT START UP I HAD 40.
COULD IT BE THAT SIMPLE ?WHAT IS THE OPERATING TEMP OF A 454 ? IS THE OIL COOLER MANDITORY TO KEEP THE TEMP LOW.I THOUGHT IT WAS A MOTORHOME THING SO I NEVER HOOKED IT UP? WHAT SHOULD OIL PRESSURE BE AT IDLE ?
THANK YOU AGAIN EDD
post #2 of 7 (permalink) Old Mar 30th, 01, 02:29 AM
Where is your oil pressure guage hooked up if I remember it was in the front on the drivers side I don't know what is up there that would work as a pressure tap. I have never delt with the oil cooler adapter you have so I can't help there. Did you ever look a the main bearings?
oger is offline
post #3 of 7 (permalink) Old Mar 30th, 01, 02:35 PM Thread Starter
the fitting is on the front lt side,the filter that is on there is from a small block chevy.i used the filter plate so i could elminate the oilcooler.now that might not seem like a probum but now the oil filter was sitting in the block about 2 inches(wraped by the exhust),instead of outside of the block 4 inches as it would be with the stcok cooler/filter plate.i managed to totaly mangel my oil filter trying to get it off , once its removed i will reinstall the stock cooler having to rerout the exhust to clear it.i soldered my radiator today that should help.(it was only 1/2 full)im going on the assumption that the combination of the low radiator water,wrong oil filter and no oil cooler was the root of my problum.if im wrong im not out any thing.and i hae a oil cooler installed.
any idea on what the temp psi ect should be?
thanx edd
post #4 of 7 (permalink) Old Mar 30th, 01, 03:49 PM
Bill
Eddy,
I did not see your origonal post, but if your motor had an oil cooler and you did not reinstall it, I am pretty certain that there is might be an extra oil filter bypass valve that needs to be removed. I would have to look at your block to be certain. I also do not know the condition of your motor, but as long as you have 10lbs of pressure for every 1000 rpm, dont worry too much about the pressure at idle. In other words if you have 40 lbs going down the road at 2500 rpm, you have more than enough.
Hope this helps,
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
1973 Z-28 ..one family car...Brother bought it new in 73
BillK is offline
post #5 of 7 (permalink) Old Mar 30th, 01, 03:59 PM Thread Starter
BILL MY ORIGINAL POST WILL PULL UP UNDER THE 5 DAY POSTED ITEMS.THE BY PASS I BELIVE IS BUILT IN TO THE ADAPTER PLATE,.THERE IS A CARBON FIBER LOOKING DIME SHAPED VALVE IN IT.SO 10 LBS FOR EVERY 1000 RPM.OK AT 2000 RPM IT HAS 20 PSI.IT TAKES A SECOND TO CLIMB THERE THOUGH.
THANK YOU EDD
post #6 of 7 (permalink) Old Mar 31st, 01, 04:00 PM
You have still got me on the oil pressure line are you hooked up above the oil filter? or did you tap into the front of the main galley. Does it still knock is it a 4bolt block with 2 holes above the filter pad?
oger is offline
post #7 of 7 (permalink) Old Apr 5th, 01, 07:15 AM
is your caps lock key broke?
Chris Edwards is offline
