shooting off belts at high rpm's - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 4th, 01, 04:35 PM Thread Starter
joseph l clance
joe clance's Avatar
69 camaro w/V8 p/s . At high rpm the alt/water pump/crank belt will fly off. Replaced belt (45" 11mm cogged and un cogged)numerous times. THe crank pully appears really large and could contribute to very high belt speed. Pulleys look good and alignment also looks good (eyeball). What is the proper pulley diameter of the crank shaft pulley? Is there a worthwhile serpintine pulley/belt system that is good for high perfomance camaro? Thinking of replacing w/ electric fan system. Any experiience or suggestion for surpentine pulley/belt and electric fan system? All comments suggestions appreciated.
thx
joe c.
joe clance is offline
post #2 of 10 (permalink) Old Apr 4th, 01, 04:55 PM
Thumbs up
I had the same problem. I bought used crank,water pump and alt. pulleys from a 85-86 chev truck, they have a combination serpentine belt drive for the alt. and v-belt for the power steering. I also installed an electric fan at the same time, now i can rev 7 grand all day and not throw a belt
67 RS
355, SUPER T10 4 SPD
9" FORD
67FREAK is offline
post #3 of 10 (permalink) Old Apr 4th, 01, 05:41 PM
I had the same problem. There are a few things that you want to check. The biggest thing is, is the pulley on the altinator straight? If it is check the pulleys that the belt comes into contact with. Youll probably have to remove the belt and spint the pulley slowly to see any wobbles. Or it could be a bent altinator bracket. I have a modified alt bracket on so it bends out a little. So the tighter it is the further it sticks out. The way I fixed this problem was to get a bigger pulley. You just have to be carefull that you are charging the battery if you do this. Hope this helps.
devildawg is offline
post #4 of 10 (permalink) Old Apr 4th, 01, 05:45 PM Thread Starter
joseph l clance
joe clance's Avatar
<BLOCKQUOTE>quote:</font><HR>Originally posted by 67FREAK:
Does the tension adjustment remain at the alternater? Did it remain a 45" Belt, and is it a wide multi-groove belt? I would go with that set-up because the p/s belt never shoots off.
<HR></BLOCKQUOTE>
Where did you acquire the electric fan? Any suggestions from your experience on thermo-sensor,wireing, and fan diameter and manufacturer?
look foreward to your response.
thx
joe c.
post #5 of 10 (permalink) Old Apr 4th, 01, 06:16 PM
two things to do. 1st make sure the pulleys are alligned with each other . 2nd you can buy deep grove pulleys that will help.
6-71BlownCamaro is offline
post #6 of 10 (permalink) Old Apr 4th, 01, 06:23 PM
David Pozzi
davidpozzi's Avatar
Put a straight edge on the pulleys and make sure they are straight, not only in angle but front and rear position.
You can buy shims for the water pump pulley to move it forward, if that is what you need.
Z/28 deep grouve pulleys are a ton better than stock pulleys.
They are still available from GM, I think.
I know the short water pump deep pulleys are.
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
davidpozzi is offline
post #7 of 10 (permalink) Old Apr 5th, 01, 03:39 AM
Also, don't thing that belt brands won't have anything to do with it. Mine will throw a NAPA belt in a few miles, but my Mercruiser belt has been on for 2 years now.
1992 Firebird 355/Six Speed (Soon to be LT1)
1991 RS 350 / 700-R4
1987 Toyota Pickup 383 / 500 + HP 10.963 @ 119.95 Slicks / 11.997 @ 114.23 Radials
"Speed KILLS, so drive a FORD and live forever!"
http://personal.lig.bellsouth.net/~racer383/
Member of the "unwanted" 3rd Gen group.
Mark W. Winning is offline
post #8 of 10 (permalink) Old Apr 5th, 01, 04:24 AM
Moroso sells a deep as heck groove alternator pulley. it worked for me.
68ragtop is offline
post #9 of 10 (permalink) Old Apr 5th, 01, 11:11 AM
I had this same problem all of last year. Here is the link to the discussion. https://www.camaros.net/forum/Forum5/HTML/000545.html I had several items all adding up to a problem. First there was a small dent in my crank pulley. Second was poor alignment. Use a metal carpenter's L square to check them with no belts on. If you are just looking at the pulley's they are best viewed by standing beside the car facing toward the front of the car and turning your head sideways to look at alignment. This may sound strange, but it works. Last, I had used a flex fan. When you revved the engine you could see slack in the long side of the alternator belt for a moment due to fan drag. What finally fixed it was changing back to a clutch fan. I also put on a 5" deep groove alternator pulley from Summit, $20. Not a bad idea if you are going to turn some RPM's. Good luck.
Chris Davis is offline
post #10 of 10 (permalink) Old Apr 5th, 01, 05:29 PM
Every time I get heavy into it, mine squeel. Mine are lined up fine, tried diff. pullies and nothing has worked. I think I would like to use timing belts.
69er
69 Camaro 454
71 Nova 454
If your not living on the edge then your taking up too much space
69er is offline
