brake pulsating... please help! - Team Camaro Tech
post #1 of 7 (permalink) Old Feb 9th, 03, 09:50 AM Thread Starter
does anyone ever have a problem with their camaro brakes? my lovely z28 has been with me for 3 yrs. but this is the third time i have to change the brake rotors becuz they seem to be out of round...
the dealer says there are 2 causes, overuse of the brakes, and heat... considering my driving habits, these two reasons just dont apply to me.... anybody ever experienced this before??
nitrobutt is offline
post #2 of 7 (permalink) Old Feb 9th, 03, 12:01 PM
Administrator
Al McKenzie
depends on the year, if your's is a fourth gen then the brake rotors are indeed an issue as they tend to develop a warp without really being excessively used. i've heard some of the owners get frustrated enough (even after warranty replacements) they buy an quality aftermarket brand and that's the end of the problem.
Al is offline
post #3 of 7 (permalink) Old Feb 9th, 03, 01:25 PM
choptop's Avatar
I had a similar problem on my daily driver VW. Replaced the rotors under warranty twice before the problem abated. I think they had a bad batch of rotors (weak metal) that warped easily. The last set put on has been flawless for over 20K miles now. The other two were the factory originals (changed at 5K) and 1st replacements (changed at 10K) which both warped very quickly under normal driving.
Scott- Austin, Texas
My '68 RS/ZZ4
choptop is offline
post #4 of 7 (permalink) Old Feb 9th, 03, 03:50 PM
on cars with the 2 piece rotors, you need to be sure to tighten the lug nuts evenly, and to the proper torque value. tighten them up with an impact wrench in a circular pattern like you see the Winston Cup pit crews do, and i can almost guarantee they will warp. use a torque wrench and go every other lug nut, sneaking up on the final torque in 2 or 3 steps, and you might not warp the rotor.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see dirty pics here of a car that gets driven http://community.webshots.com/user/novaderrik
novaderrik is offline
post #5 of 7 (permalink) Old Feb 10th, 03, 05:42 AM
I think 3 changing the rotor three times in three years means the dealer is the guy over tightening the lugs. If it's a chevy authorized dealer I'd contact chevrolet and get my money back. You'll find their numbers on their website.
Snatchin'gears is offline
post #6 of 7 (permalink) Old Feb 10th, 03, 09:38 AM
Send a message via MSN to kausboy
I have to agree with Novaderrick --The dealership I worked for did not want us to put the wheel back on with an impact wrench -we had to use hand wrenches and a torqure wrench. Most places are now using "torque sticks" I don't put a lot of faith in those things. Whenever I have work done that invoves removing a wheel I always take it home and slap a torque wrench to it!
kausboy is offline
post #7 of 7 (permalink) Old Feb 11th, 03, 02:40 PM
Den
DenRS's Avatar
I had the brakes done twice on my 96RS while it was under under the 3year/36,000 deal. I have the Y87 performance package, so I have the same brakes as the z28. I only have 45,000, so I haven't had the brakes done since my warrenty expired, but they still pulse. Since you have a z28, I would not use a impact gun as you could damage your aluminum rims and never torque them past 100 ft pounds. That will definitely warp the rotors. The rotors on the 4th gen cars are thin and warp easily. I would replace the warped rotors with a high quality rotor from Baer etc. The pulsing should go away with the new rotors unless you really beat on your car.
DenRS is offline
