69 taillights - Team Camaro Tech
post #1 of 8 (permalink) Old Apr 2nd, 01, 06:10 PM Thread Starter
Gary
I replaced the rear wiring harness on my conv't. from the dash to the rear. The problem is the inside rear red tailights are twice as bright as the outside ones. I know that when the lights are on, they should all be the same brightness. Any ideas-thanks.
Gary Dorion is offline
post #2 of 8 (permalink) Old Apr 2nd, 01, 07:05 PM
ok i have two answer's for ya! for the price of one....
bad ground, it is best to run a ground strap from both tail light bucket's to the body to create a comon ground, also grease all conection's with lubraplate to seal out water and corrison.
you need to check the bulb's, if you are not useing the right one's or thay have been made wrong you will get this. there is a candle power rating for all bulb's, and tail light's/turn signal's should be 1157. back up light's and running light's are 1156 i believe.
on the 1157 the brake/turn part is brighter than the running part. if you managed to install them backward's, they have to offset nub's for alienment, you reverce the part you use for running to the part that should be the brake/turn signal.
ilbl8 is offline
post #3 of 8 (permalink) Old Apr 3rd, 01, 04:32 AM
The inner bulbs are smaller than the 1157. Go down to your auto parts store and find a bulb that is samller than the 1157 but has the same base. That's what I have in mine. The 1157 will work if you do as explained above...
69 Z/28
www.camarogenerations.com
X77D80 is offline
post #4 of 8 (permalink) Old Apr 3rd, 01, 10:27 AM
JC
Send a message via AIM to JC69RSZ28
My guess is that you are using the same blub for the inside and out side light, the inner ones are 1156, single filiment and the outside are 1157 dual filiment. unless of course you have a RS then they are both 1157. The inner ones on NON-RS cars are just taillights and the outer ones are turn signal,brake and tail. good luck
1969 RS Z28 Black, white deluxe interior,
http://www.corvetteforum.net/c3/corvettj
JC69RSZ28 is offline
post #5 of 8 (permalink) Old Apr 3rd, 01, 05:26 PM Thread Starter
Gary
Thanks to you all, but I'm sorry to say that the bulbs I'm using are the 1157 & 1156. I was hoping to get away from having the running lights in the rear effect. I'm still open to any ideas, and I could just not drive at night.-NOT
post #6 of 8 (permalink) Old Apr 4th, 01, 09:05 AM
The inside lights are a smaller bulb with the large base. I can't remember the number right off but you should be able to find them in any store. If not I will get the number off mine and advise you later on.
Black69 is offline
post #7 of 8 (permalink) Old Apr 4th, 01, 02:26 PM
Rick
Well, well, well. Folks, this is my little brother Gary. Still can't get your lights right? I think you should give me your car and have it taken care of properly. I should have your carb rebuilt by Fall.
RickD is offline
post #8 of 8 (permalink) Old Apr 4th, 01, 05:58 PM Thread Starter
Gary
I have 2 replys. 1 To RickD, I know where you live. 2 To Black69, I'm open to suggestions. Just for fun,if you would check your bulb #'s and let me know, that would be great. Thanks to you both!!
