cold start problem/tpi - need help please! - Team Camaro Tech
post #1 of 4 (permalink) Old May 8th, 01, 01:22 PM Thread Starter
i have a 1987 iroc z 305 tpi. it won't crank when cold (overnight). the only way to crank it is to hold down the accelerator 1/4 to a 1/2 inch and it takes several times to get it cranked. no computer codes are coming up.
cold start valve or cold start switch maybe??
any suggestions on how to check or solve this would be greatly appreciated. thanks!
dchart1 is offline
post #2 of 4 (permalink) Old May 9th, 01, 09:25 AM
two things to check. cold start injector.
And if that dosent do it then you probably have a injector(s) leaking down.
6-71BlownCamaro is offline
post #3 of 4 (permalink) Old May 11th, 01, 05:02 PM
Wink
what about the IAC? its a valve that opens at start up to let air by because the throttle plate is closed.its also used if you have A/C when the motor senses the drag it opens up a little more. with you depressing the throttle a little your letting air by. hope this helps.
sldhd is offline
post #4 of 4 (permalink) Old May 13th, 01, 02:35 AM
This is typical of low fuel pressure. You will likely need to replace the pump. Ray
RABarrett is offline
