Vacuum actuators For A 69 Camaro - Team Camaro Tech
post #1 of 3 (permalink) Old Jun 1st, 01, 02:34 PM Thread Starter
Unhappy
I have 2 69 Rallysport Camaros both with reproduction actuators. I can't get them to work ! They'll go one direction but not the other. I've checked all the lines for leaks and it all seems ok . Someone told me that the repoduction actuators were built wrong and the vendors were still selling them . Is this true , can anything be done to resolve the problem with my cars . HELP !
camaroroupe is offline
post #2 of 3 (permalink) Old Jun 3rd, 01, 05:54 AM
William
William's Avatar
The system is activated by a 2-way vacuum port on the headlamp switch; if one port is open the other is closed. The port is sealed by small rubber boot contained in a metal slide. The slide has a tab formed at 90ļ to engage the switch. The tab breaks off resulting in only open or only closed. The non-gauge RS h/l switch is still available. Yours should be repaired if the car has factory gauges as the switch is different.
William is offline
post #3 of 3 (permalink) Old Jun 3rd, 01, 07:02 AM Thread Starter
Thumbs up
Thanks for the idea . They both have the old original swithes . I'll I'll check them out and see if they work properly .
