4 speed does not fit new engine crank! - Team Camaro Tech
post #1 of 2 (permalink) Old May 8th, 01, 07:09 PM Thread Starter
Exclamation
My Muncie 4-speed does not fit the crank on a new engine! No pilot bearing. Can I get an adapter or pilot bearing setup to fix my end shaft on my transmission?
Thanks, Jammer
Jammer is offline
post #2 of 2 (permalink) Old May 8th, 01, 11:36 PM
john
Get a pilot bearing and tap it into the crank end. As long as you're running a small block with a 2 piece rear seal, I believe it will work fine. Don't forget a small dab of grease where the input shaft contacts the pilot bearing if you use a bronze one.
john
fujimook is offline
