help with my sb - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 3rd, 03, 04:12 PM Thread Starter
my stock 305 has run well for a while, but recently, if i run it a long way(~50mi), when i stop it idles really high(~2000) and i try to shut it off, but it keeps running(aroung 200rpms guessing)sometime for 3-5 minutes and puffs blue smoke at the same time, car doesnt smoke otherwise. i have tried changing the timing but doesnt seem to help. the only thing i did different, around the time this started, was change plugs in it. supposed to be the stock plug.i dont know but i would apprieciate any ideas. thanks guys
Sean
ss283 is offline
post #2 of 7 (permalink) Old Apr 3rd, 03, 05:39 PM
Try tuning the carb. It might be way too rich keeping some hot carbon spots fed.
Snatchin'gears is offline
post #3 of 7 (permalink) Old Apr 4th, 03, 05:00 AM
robert
rolling-robert's Avatar
funny, blue smoke means too rich, but high idle means too lean
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
post #4 of 7 (permalink) Old Apr 4th, 03, 05:49 AM
J
Blue smoke means burning oil.
Black smoke means too rich.
magisnyc is offline
post #5 of 7 (permalink) Old Apr 4th, 03, 06:11 AM Thread Starter
the blue smoke doesnt bother me as much as why is it running at low rpms after the motor is shut off by the key. anyone else had this problem? i have had a few other vehicles do this but only for a few seconds, this one is for at least a minute.
ss283 is offline
post #6 of 7 (permalink) Old Apr 4th, 03, 06:45 AM
Send a message via MSN to kausboy
If it is still running (rough) AFTER the ignition is off it is called "run on" means your engine is still getting air from somewhere -I would have to say you have a vacuum leak. The blue smoke during run on would be somewhat normal as it is "opulling over" fuel in the carb and not burning it completly due to no spark from the spark plug (you did say the ignition was off). check to make sure your secondaries aren't stuck open a little.
kausboy is offline
post #7 of 7 (permalink) Old Apr 4th, 03, 08:37 AM Thread Starter
thank you
ss283 is offline
