92 camero speedometer problem - Team Camaro Tech
post #1 of 8 (permalink) Old Jun 18th, 03, 11:02 AM Thread Starter
my speedometer/odometer does not work on my 92 camero. The manuals i have purchased show that it should have a speedometer cable, upon pulling our the entire gage cluster there is no place for a speedometer cable to hook up to, i checked all the gears and they are working fine. im not sure where to go now please help if you can if more information is need please let me know.
robert campbell
cowboyfan is offline
post #2 of 8 (permalink) Old Jun 18th, 03, 11:24 AM
Angry
Did it ever? Maybe thats the prob it isn't there
kf6myv is offline
post #3 of 8 (permalink) Old Jun 19th, 03, 09:16 AM Thread Starter
then where would the problem be
robert campbell
post #4 of 8 (permalink) Old Jun 19th, 03, 10:00 AM
Well I was being a little serious and silly at the same time. My first question is 1) Did the speedometer ever work?
The two times I have delt w/ them on older Camaros the cable comes out the side of the trany and up through firewall and plugs into the back of the speedometer. No way in heck you could miss it. Is this an electronic display of any kind?
kf6myv is offline
post #5 of 8 (permalink) Old Jun 19th, 03, 10:04 AM Thread Starter
gagues are not digital, there are 2 computer chips sitting on the bottom of the gage cluster, and absoutly no place for a cable to hook into the speedometer, i bought the car used and the speedometer/odometer was not working when i bought it
robert campbell
post #6 of 8 (permalink) Old Jun 19th, 03, 01:28 PM
And what were you sating about gears? Anyway I went to autozone.com since sometimes they tell you where the parts are but no luck. I did however see a cable for like $4 and a speed sensor or sumtn for like $50+. May want to go to a shop and see what those look like and then find them on the car.
kf6myv is offline
post #7 of 8 (permalink) Old Jun 19th, 03, 01:30 PM Thread Starter
i know what the cable looks like and i just crawled out from under the car and it is not their i do not even see a place for the cable but i will look at the sensor. thanks for the help [img]graemlins/beers.gif[/img]
robert campbell
post #8 of 8 (permalink) Old Jul 16th, 03, 08:17 PM
if the speedo is not working and you are not getting a "service engine soon" light, then the sensor in the trans tailshaft is probably ok... otherwise you would be getting a code24 (VSS) and the light would come on...
so its either the speedo head itself or a connection inbetween...
check for a code 24 first tho
68 camaro... your tipical hipo 350... stl crnk... h beam rods full floating pistons mild cam, auto trans (wanting 700r4)... gears 3.73's... smokes tires lots of fun... also 87 IROC 305TPI 5-speed
zroc is offline
