Header Ticking Noise - Team Camaro Tech
post #1 of 8 (permalink) Old Aug 29th, 03, 09:59 AM Thread Starter
Ray
Just replaced my factory manifolds with hedman 65003 coated headers. I used the gaskets that came with the headers. Now I get a ticking noise. Replaced gasket with factory style(fel pro kit) and some high temp sealer but same thing tik tik tik.....
Any suggestions? how much better are those higher priced aluminum or copper gaskets?
Thanks Guys, Ray
Rayzor is offline
post #2 of 8 (permalink) Old Aug 29th, 03, 12:04 PM
Ray, that ticking noise may be a spark plug wire that is bad and closer to the header tube than the factory exaust manifold was. If that's not the case you may want to put a straight edge across the headers as well as the head surface to make sure that they are flat. Also, you shouldn't need any sealer with the headers, especially new ones. I've always had good luck with the Fel Pro header gaskets. Hope this helps. Good luck, Jim
Jim & Yvonne
1968 Camaro
468 BBC, Turbo 400, 4.10 12 Bolt.
2010 Camaro SS/RS, Black on Black Leather
2008 GMC Crew Cab 4x4, LMM Duramax, Allison 6 Speed,
6" Cognito Lift, 35" Nitto's
Ledfoot is offline
post #3 of 8 (permalink) Old Aug 29th, 03, 09:16 PM Thread Starter
Ray
Thanks Jim! Its positively an exhaust leak at the head to header area.It started immediately after installing headers. (in fact my friend has a 68 camaro, installed the same headers and has the same problem)My car runs fine no ignition miss,wires do not touch primary tubes.
seems to be leaking between cyl #3 and cyl #5.I have stock heads, Maybe the large 1 3/4" primary headers I have aren't a good match
Thanks, Ray
Rayzor is offline
post #4 of 8 (permalink) Old Aug 30th, 03, 04:27 AM
MStennes's Avatar
Rayzor,
I had the same problem and I went with the MR. Gasket copper header gaskets, they were a little spendier than the cheap fiber gaskets but my exhaust leaks went away.
69 RS/SS vert tourer, LS7, T56, Baer, Hydrooost, GW, etc, etc,
Welfare is completely against freedom and the principles of american life, paying people not to work by stealing from the people who do is insanity.
MStennes is offline
post #5 of 8 (permalink) Old Aug 30th, 03, 09:13 PM Thread Starter
Ray
Thanks Mike! I think I will do the same and try those premium type gaskets.It'll be my third time so I should be getting faster at it Sometimes I wish I didn't have that H-pipe.
Thanks again, Ray
Rayzor is offline
post #6 of 8 (permalink) Old Aug 31st, 03, 08:00 AM
I used Percy's dead soft aluminum gasket and Stage 8 locking bolts. I put them on in april and havent heard tick since. I highly recommend this set up. However, you could have a warped header flange, if so, no gasket will help. Im not sure if a straight edge is accurate enough to check for that. Perhaps a machinist should look at it.
67 RS Convertible, 355ci, 650cfm, 5-speed, 12-bolt, 3.90 gears. 12.7 @ 110 mph
Marktat is offline
post #7 of 8 (permalink) Old Aug 31st, 03, 10:38 AM
Chris
ckaram's Avatar
A last thought is to use the dead soft aluminum and the felpro together.
That's how I eliminated mine. I chased it constantly with just the aluminum's on there.
Check my rides:
1968 Camaro Convertible LS1, T56
2016 Challenger RT Scat Pack Shaker
ckaram is offline
post #8 of 8 (permalink) Old Aug 31st, 03, 06:27 PM Thread Starter
Ray
Thanks for the info guys! [img]graemlins/thumbsup.gif[/img] I guess I'm not the only one who went through this. Hope it this will be the last time for me..
Thanks again,Ray
Rayzor is offline
