Fuel Tank problem - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 3rd, 02, 06:34 AM Thread Starter
Thumbs down
I've just finished reinstalling my fuel tank into my '69 after cleaning the exterior and painting it. I installed a new sending unit also. My problem is that it appears to be leaking from the point that the filler neck is soldered to the tank. Is there any way seal this from the surface?
'69 Z11 Pace Car, 350/4 speed, manual top, console w/gauges, tilt rosewood wheel, AM radio
drdave69 is offline
post #2 of 5 (permalink) Old Jan 3rd, 02, 07:59 AM
Cool
You could try some JBWELD or liquid solder around the area that is leaking.
Hope this helps!!!!!!!!!!!!!!!!
The Trickster!!!!!!!!!!!!!!!!!!!
trickster is offline
post #3 of 5 (permalink) Old Jan 3rd, 02, 01:16 PM
I have had luck in the past taking them to my local radiator shop and having them solder it. They filled ity with water first to clean it out. Then I had to flush it out with solvent to remove the water. Then again a new one is not that bad in price and adds alot to the underside of the car.
tracyracy is offline
post #4 of 5 (permalink) Old Jan 3rd, 02, 04:57 PM
Talking
Qualco gas-tank leak sealer $2.49 at ames
no dismantlimg needed
Dave91RS is offline
post #5 of 5 (permalink) Old Jan 4th, 02, 04:05 AM Thread Starter
Dave91rs, what is 'ames'? If it is an Auto Supply store, is there another source (such as AutoZone, Discount) for the sealer? Thanks for the suggestions. I had just finished installing the tank after cleaning and repainting it and really don't want to have to remove it again.
drdave69 is offline
