Please help i screwed up! - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 29th, 01, 05:57 PM Thread Starter
Angry
I pulled my distributer the other day and didn't mark it properly and not I can't get the car to even start it back fires through the exhaust and the carb depending on how i turn the distributer. The biggest problem is I get the distributer where i want it and try to put it in and it goes all the way down and stops about a 1/4 from being flush with the manifold and then it won't go down. When i do get it to slide in all the way it is in the wrong place and the timing is all jacked up. I need help with the basics i have to being doing somthing simple wrong. How do I fix this???
69CamaroRacer is offline
post #2 of 10 (permalink) Old Apr 29th, 01, 06:09 PM
chris
if i remember right you can set # 1 at tdc and then set the rotor to # 1 this should make it fire right up
c4boom is offline
post #3 of 10 (permalink) Old Apr 29th, 01, 06:11 PM Thread Starter
i tried that and i can't get the distributer to sit in the block right so i can do that.
post #4 of 10 (permalink) Old Apr 29th, 01, 06:55 PM
Thumbs up
Oil pump is at the bottom of the Dist. - it has a slot that the Dist base sits in (look at bottom of Dist Shaft - you have to line these up (all the while getting it to slid in pointing at #1 wire)
Easiest way is to go buy a REALLY LONG screw driver (about the length of you dist shaft - and then some)
You can then turn the pump so that the slot lines up with the dist shaft -
Now the fun part - the dist will turn when the gears line up. Figure accordingly - so don't try to drop in already pointing at #1. Line it up with the next wire over and it should turn just about right.
Good luck.... it's frustrating - but not really that hard -
Just make sure that you are truly at TDC and it is lining up on #1 wire.
Dobek is offline
post #5 of 10 (permalink) Old Apr 29th, 01, 07:33 PM
Dale
If you get the dist. in the right spot and it wont drop alltheway.Have someone bump over the engine with the starter,while lightly pushing down on the dist.The distributor will turn,and finally fall into the oil pump drive.
68 z28 ,68 rs 327 ,73 454 vette, 2 goofy kids
dale68z is offline
post #6 of 10 (permalink) Old Apr 30th, 01, 06:49 AM Thread Starter
Here is an update....
I got it all running and it sounds really good but when I put the timming light on it, it reads 28* at idle. WHat gives? I am going to drive it and see if I get any hesitation r spark nock I'll let you know how it goes. I am thinking that if there is a problem it has to be in the distributer maby a vac advance sticking all the way open?? What do u think.
post #7 of 10 (permalink) Old Apr 30th, 01, 08:23 AM
I saw the post and thought you had done something real dumb {got married} I see you got it started you should be able to work out any problems now.
oger is offline
post #8 of 10 (permalink) Old Apr 30th, 01, 10:24 AM
Eric
There's a connector to the ECU on the distributor. You must disconnect it to set the base timing. Plug it back in when you're done and let the computer worry about the rest.
Eric68 is offline
post #9 of 10 (permalink) Old Apr 30th, 01, 11:50 AM Thread Starter
Angry
Well I test drove the car and it is still all jackd up. It barely starts and when you get on it it pops through the carb. I was sittin at a light and hit it and all i heard was poof it popd right out of the carb i thought I killed it. Lucky for me I have an edelbrock carb .. no power vlves. It cruses ok but you can't get any rps out of it. I got mad and took it to a shop! let it be their headache for a while!
post #10 of 10 (permalink) Old Apr 30th, 01, 05:28 PM
Huh, I recently posted how to install your distributer from scratch at https://www.camaros.net/forum/Forum1/HTML/004600.html
I would cut & paste the text here, but it doesn't line up well, so just look for about the 20th post on that url.. 2nd up from the bottom as of today..
-ibjoe
now: '73 LT1; '79 Z28
then: '67 coupe; '88 IROC; '95 Z28
ibjoe is offline
