Black smoke when getting on the Holley - Team Camaro Tech
post #1 of 4 (permalink) Old Apr 22nd, 01, 07:07 PM Thread Starter
Purty black smoke with a little extra gas. No black smoke at idle. I am having some timing issues so this could be it. I just know I have had the same issue with this Holley before.
71 maro is offline
post #2 of 4 (permalink) Old Apr 23rd, 01, 06:32 AM
Make sure you get the timing right first then go from there. It sounds like it is retarded. I always recommend and advance curve kit most stock curves are way to slow. A simple kit will make a world of difference in how a car runs.
oger is offline
post #3 of 4 (permalink) Old Apr 24th, 01, 12:46 PM
Eric
Wink
Oger, how can you say the man's car is retarded? It is a Camaro.
If you run a Holley carb, it could be a blown power valve - especially if it popped back through the carb because of a timing problem.
Eric68 is offline
post #4 of 4 (permalink) Old Apr 25th, 01, 07:13 AM
i think he means the timing.
Chris Edwards is offline
