oil on plugs - Team Camaro Tech
post #1 of 11 (permalink) Old Dec 6th, 01, 10:01 PM Thread Starter
i pulled the plugs again on my 383 with only 100miles on it. i drive it nice all the time and it still has oil on it. the shop that built the motor did a compression test and it showed up good. do i need to give it time for the rings to settle. they are chromoly rings and i heard they have a little blow by for the brake in period. any advise
383camaroSS is offline
post #2 of 11 (permalink) Old Dec 6th, 01, 11:17 PM
Joe
Exclamation
Sounds like valve seals
joe
69 Rat-Infested Resti-Clone
WCA Member
[email protected]
69 Pics http://albums.photopoint.com/j/Album...559&a=11674961
Joe G is offline
post #3 of 11 (permalink) Old Dec 8th, 01, 06:13 AM
<BLOCKQUOTE>quote:</font><HR>Originally posted by Joe G:
joe
<HR></BLOCKQUOTE>
I had the same problem on a new engine, but it was due to having the engine too lean on initial start up which cooked some valve seals due to heat. i just replaced the seals on a engine that only has 124 miles so i will see later this week if it fixed the problem.
If you are running to rich it is possible that to much gas is washing the hole check the oil for gas.
Dave Brinson is offline
post #4 of 11 (permalink) Old Dec 8th, 01, 11:25 AM
hello?
cavemate is offline
post #5 of 11 (permalink) Old Dec 8th, 01, 06:52 PM
joseph l clance
joe clance's Avatar
worlg products' heads?
joe clance is offline
post #6 of 11 (permalink) Old Dec 8th, 01, 08:39 PM
How does it seem to run otherwise? Does it idle ok?
travis is offline
post #7 of 11 (permalink) Old Dec 10th, 01, 09:53 AM
If your running too thin oil then go to a thicker oil.
4-spd Z's owned: 68,70,71,77new,78new,80new
Home Pages
http://members.rogers.com/mlvd/
http://members.rogers.com/1970-z28
COPO is offline
post #8 of 11 (permalink) Old Dec 11th, 01, 03:22 AM
Send a message via AIM to Spames
How much oil are you burning? 1 quart or so every 3000 isn't too bad, even for a recent re-build. I've even heard some people say that a little bit of oil on the plugs means you are getting excellent lubrication, which isn't a bad thing. My opinion is to change it at 1000 (it's recommended that you change it early on a new build), then let it go for another 2000, and see how much you are burning.
68 Coupe, 350 4-speed
Jim's Camaro Corner
Spames is offline
post #9 of 11 (permalink) Old Dec 11th, 01, 06:54 AM Thread Starter
i run 2050. and if its the valve seals its ok i am getting new heads in feb. thanks for the help.
post #10 of 11 (permalink) Old Dec 12th, 01, 06:32 AM
Chances are if you have oil on plugs it is getting past the rings,this happens sometimes with fresh rebuilds until rings seat but if you did not bore the cylinders during rebuild and installed new pistons chances are you just wasted your money
Branded is offline
post #11 of 11 (permalink) Old Dec 12th, 01, 09:56 AM Thread Starter
it was bored 30 over so i hope it is just valve seals or it being a new motor.
thanks
