68 chevelle fuel gauge/sender fixed - Team Camaro Tech
post #1 of 2 (permalink) Old Jun 2nd, 12, 07:24 PM Thread Starter
Howard
About a week ago while driving the 68', I noticed the fuel gauge pedded at the full mark. Knowing that the day before it showed half. I first looked under the dash at the connections and they looked good. I went to the ground wire from the tank to the body,removed it and cleaned the looped wire end and body to clean metal and reattached.Still no help. Next I disconnected the sender lead (brown wire) inside the trunk and attached a jumper wire from the brown wire connector (that feeds signal to the gauge) and grounded it.Turned the key to the ON position and the gauge went to empty (this confirmed the gauge is working correctly).So that showed that I had to drop the tank and test the sender.I removed the tank/sender (original).Rebuilt the sender by cleaning the post, metal flex ribbon and contacts inside the float sensor.Reconnected the brown wire and ground inside the trunk and tested the sender by moving the float arm down,turned the key ON and it went to empty,moved the float arm up,turned the key ON and went to full. Sender tests OK. I decided to use a flashlight to see how the inside of the tank looked through the sender hole (rust, trash,sediment,etc.) and found a 36" piece of 1/2" hard vinyl tubing laying in the tank. This had been there a LONG time by the scratches on it. Someone appearently lost it trying to syphon gas years ago and it lodged under the float arm making it show "full".Removed it and reassembled everything back and all is back to normal.
Just Having fun with all My Big Block Toys!!!
bbmusclecars427 is offline
post #2 of 2 (permalink) Old Jun 2nd, 12, 08:20 PM
69-Pace's Avatar
Re: 68 chevelle fuel gauge/sender fixed
Good save.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
