Turbo 350 - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 3rd, 12, 05:33 PM Thread Starter
Ron
Turbo 350
I have a question i have a 84camaro with a 350 turbo tranny thats stuck in first even after manual shifting from under the car what would cause the tranny to lock up like that?
Smith84 is offline
post #2 of 5 (permalink) Old Jun 5th, 12, 12:32 PM
Re: Turbo 350
Bad govenor, or a stuck shift valve most likely. Good news is, the govenor is easy to get to with the tranny in the car. The valve body isn't too bad either, except you have to drain the fluid and remove the pan to get to it.
dnult is offline
post #3 of 5 (permalink) Old Jun 5th, 12, 02:45 PM
Jeff
yellow69RS's Avatar
Re: Turbo 350
A vacuum modulator with no vacuum causes a late or never upshift. Hose off or line crimped shut? bad modulator?
Jeff
yellow69RS is offline
post #4 of 5 (permalink) Old Jun 7th, 12, 02:43 PM
Re: Turbo 350
Good point Jeff...perhaps the easiest to check of all.
dnult is offline
post #5 of 5 (permalink) Old Jun 7th, 12, 04:29 PM Thread Starter
Ron
I had to slam it in park from reverse, lost brake pressure and that was the only way to get it to stop rolling
Sent from my SCH-R680 using AutoGuide.Com Free App
Smith84 is offline
