pcm not triggering egr sol 1 - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 16th, 03, 03:55 PM Thread Starter
for a year i was under the impression my egr valve was bad,i bought a used one, and still got a solenoid 1 failure code, bought a new one today
and still got a code, the plastic cover on the connector wires seem fine , is it possible the wires were damaged from the heat, but the plastic covering was not? also, if it is the pcm that will not trigger the solenoid, is there a specialty shopp that can repair the pcm, without buying a new one?
a man's got to know his limitations
pablo escobar is offline
post #2 of 3 (permalink) Old Apr 16th, 03, 05:29 PM Thread Starter
i was also wondering if it could be a blocked egr passage, or something similiar?
post #3 of 3 (permalink) Old Apr 16th, 03, 06:45 PM
No need to post in more than one forum. In the electrical forum someone asked if you would clue us in on the model you're dealing with. That would go a long way toward helping us help you diagnose the problem. Have you picked up a haynes manual to see if there is a diagnostic procedure you can do with a DVM? Beyond that, there are other things that can prevent the thing from coming on, but we have to know the model. Consider T-ing in a vacuum guage to see if the solenoid is in fact turning on the vacuum.
-dnult
dnult is offline
