69 Camaro won't start - Team Camaro Tech
post #1 of 7 (permalink) Old Jun 7th, 12, 08:34 PM Thread Starter
I'm looking for a sanity check before I order a replacement coil for my 69 Camaro. It's been running fine until tonight.
Jumped in it tonight to go for a ride, and it wouldn't start. It turns over fine, but didn't act like it wanted to start once. Removed the air cleaner and verified the choke is closed and accelerator pump is squirting gas. Removed the coil wire from the distributor cap and cranked over the engine....no spark. Verified the coil is receiving 12 volts when the car is in start or run position. Verified the rotor is turning when the motor is spinning over. Disconnected the wires on the distributor side of the coil and put an ohm meter across the primary windings - measured about 24,000 ohms. I think that's way too high.
The Accel distributor I have requires a coil with primary windings of 1 ohm or less. The coil is a Pertronix Flame Thrower II, and if I remember correctly the primary side of the coil should measure 0.6 ohms. Am I missing something obvious, or do you think I'm in the market for a new coil? Sure looks like it to me.
It sure was a nice night to go for a cruise....
69 RS, Hugger orange/black, Deluxe interior, Sony AM/FM/XM/CD, PS & PB. 355, forged pistons, Eagle rods, balanced, Iron Eagles, 9.4:1 CR, .038 quench, XR270HR Cam, Z28 intake, FAST-EZ EFI 2.0, Thorley Tri-Ys, TCI 700R4, 2400 stall, 3.42 posi
LukeWarm is offline
post #2 of 7 (permalink) Old Jun 8th, 12, 04:29 AM
Re: 69 Camaro won't start
You would be correct, too high of resistance. Should be typically around less than 3 ohms.
Of course, you've taken and made sure of good contact of meter leads to the coil terminals and tested the meter on another known resistance just to make sure.
You may want to change out the coil to an Accel coil keeping the same brand for the whole system, keep all the plaers of the same brand.
post #3 of 7 (permalink) Old Jun 8th, 12, 07:01 AM Thread Starter
Thanks for the input Everett.
LukeWarm is offline
post #4 of 7 (permalink) Old Jun 8th, 12, 04:35 PM
PA Camaro Guy's Avatar
Also- correct mounting position for oil filled coils- straight up. Can burn the windings if mounted laterally. No one ever is tempted to mount canister coils this way but worth reminder!
1969 Camaro 383
2.02/1.63 & 234/244 Vortec
TH350 / 12 bolt 3.73
PA Camaro Guy is offline
post #5 of 7 (permalink) Old Jun 13th, 12, 09:23 PM Thread Starter
A new coil is just what the doctor ordered. Installed the replacement and it started on the first try.
LukeWarm is offline
post #6 of 7 (permalink) Old Jun 13th, 12, 09:53 PM
Max Stewart
Send a message via Yahoo to bigbuckcity
So did you finally get to go cruisin!!!!!!!!!!!!!
bigbuckcity is offline
post #7 of 7 (permalink) Old Jun 14th, 12, 09:39 PM Thread Starter
Yep!!!
LukeWarm is offline
