Starting problem (clicking only) - Team Camaro Tech
post #1 of 8 (permalink) Old Jun 8th, 02, 08:24 AM Thread Starter
I have a 68 camaro that I can fix most everything that breaks.
I also have a 96 Camaro that I never can figure out it's problems. My qusetion is about my 96 Camaro if you don't mind.
The 96 is a 3.8L. When I turn the ignition all I get is a click. I took apart all the contacts and cleaned them The car did start a few time after that but is back to clicking only.
Is this a starter problem? Maybe something else on a modern car I should be looking for.
If it is a starter problem, my shop manual tell me I have to drop both sides of the exhaust to remove the starter. Does'nt look like fun. If this is tyhe case, it may be better to let someone else tackle this.
If you have any ideas or suggestions I would GREATLY appreciate it.
Thanks Again,
Sgrouse is offline
post #2 of 8 (permalink) Old Jun 8th, 02, 11:26 AM
May be as simple as a dead battery. Get the battery checked before you go tearing at the starter. It sounds like it doesn't have enough juice to turn over.
67 Coupe 327
Edelbrock performer package, TH350, Hotchkis suspension & sway bar, Dynomax headers and exhaust, Cowl hood
L e F t C o A s T7 is offline
post #3 of 8 (permalink) Old Jun 8th, 02, 03:48 PM
In the old days on older cars(pre 80s) your symptoms would suggest either low voltage(battery low), poor connections at battery or starter, or bad solenoid. On the newer cars my experience is battery (low or bad) & whole starter. I never try to replace just the solenoid anymore, I just throw money at it & replace starter-solenoid assembly.
good luck
billyd is offline
post #4 of 8 (permalink) Old Jun 8th, 02, 04:17 PM
Or a weak battery cable.
Scooby Doo is offline
post #5 of 8 (permalink) Old Jun 8th, 02, 05:41 PM
I know this sounds like real shade tree mechanics crap,but have a friend try and start the car and at the same time RAP the botom of the starter with a hammer. Something to try if your battery checks out ok,if it starts the problem is the sarter. Bodymen can be so crude.
69lemans is offline
post #6 of 8 (permalink) Old Jun 9th, 02, 06:28 AM
robert
rolling-robert's Avatar
i few weeks back i had the same problem,in my situation i noticed the big cable at the back of the dynamo that made contact with the engine, so there was a short-circuit!
check that first, it made a clicking sound just like your car!
rolling-robert is offline
post #7 of 8 (permalink) Old Jun 9th, 02, 04:40 PM
What happened to my 68 when it did that was in the winter when it was stored up here in Minnesota it got so cold that the lead plated in the battery actually just broke. I would charge it overnight and it would just click. Did some checking and just replaced the battery. So...word of wisdom..when you store your car for the winter...take out the battery too.
Baby68RS is offline
post #8 of 8 (permalink) Old Jun 10th, 02, 02:56 PM
....unless you live in southern california
I would HATE to have to deal with storing my car for the winter. 24/7/365 & 1/4 here.......(can't forget that leap year you know. I didn't spend all that money on this brain for nothing you know!)
67 Coupe 327
