Did my clutch or tranny die? - Team Camaro Tech
post #1 of 4 (permalink) Old Jul 15th, 02, 03:38 PM Thread Starter
Rick
Well, my car just rolled to a stop during a down shift - making sounds like nuts/bolts in a coffee can. I've got the car home and will be pulling the tranny out, figuring either the clutch or tranny went. With the motor running I can put it in any gear ( M20 ) without using the clutch and nothing happens. If I push the clutch pedal in, I hear the nuts/bolts symphony. Any ideas?
How much does an M20 weigh? Thanks for all ideas and pointers.
Rick Dorion
69 RS Conv,355,M20,4.10's and I don't worry about stone chips ( yet ).
RickD is offline
post #2 of 4 (permalink) Old Jul 15th, 02, 04:19 PM
sounds like you blew out the clutch disk?
Hope thats all you blew out!
sixt9d is offline
post #3 of 4 (permalink) Old Jul 16th, 02, 02:10 AM
Send a message via AIM to Spames
I would say the clutch too. When my M20 granaded, I'd put it in gear, pull out, and the tranny would lock up. I had to keep rocking it back and forth to get it to start rolling and get it home.
My guess on weight is 57 lbs.
68 Coupe, 350 4-speed
Jim's Camaro Corner
Spames is offline
post #4 of 4 (permalink) Old Jul 16th, 02, 04:08 PM
David Pozzi
davidpozzi's Avatar
I've had several failures of the disc. Most discs are pretty thin around the springs and can tear in that area.
David's Motorsports page
First Gen Suspension Page
davidpozzi is offline
