Alternator belt sqeeeeel - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 2nd, 02, 01:41 PM Thread Starter
Ok my alternator belt started squeeking a few days back, so when I was checking it out to adjust the tension I noticed the alt bracket had a crack in it where it attches to the header bolt.
Bought a new bracket and it still sqeels, it looks like its lined up straight.
I do have the aluminum pulleys and the aluminum/chromed alternator.
Is there something I can do to get the squeeling fixed?? Im confused that it didnt do this before???
68 RS Convertible
http://www.camaro.lookscool.com
mike_russell is offline
post #2 of 6 (permalink) Old Jul 2nd, 02, 02:50 PM
ZZ_430's Avatar
Mike, have you tried a new belt?
It may be burned up from slipping.
Don~ ZZ430DropTop
~~~~and~~~~
70 RS/Z28
67 RS/SS Convertible, 70 RS/Z28
ZZ_430 is offline
post #3 of 6 (permalink) Old Jul 2nd, 02, 03:01 PM
Mike, 69's rule
zuma's Avatar
If the belt is shiney on the sides, then it's time for a new one... To check if it's your belt and not anything else (bearing,etc), wet a small rag and squeeze a few drops on the inside part of the belt while it's running (be careful). If the squeek stops, it's the belt, buy a new one, put it on and now you have a spare...
zuma is offline
post #4 of 6 (permalink) Old Jul 3rd, 02, 12:11 PM Thread Starter
Thanks guys, I put some water on it and it stopped the noise. The belt is not more than 1 yr old but could of got damaged a little when the bracket broke.
Im off to the parts store to get a new one, nickle here, a dime there...It never stops..
I should get a pesonalized plate that says
"MONYPIT"
She's still my baby.....
1st Generation Camaro's Live on!!
68 RS Convertible
post #5 of 6 (permalink) Old Jul 3rd, 02, 01:44 PM
Mike, 69's rule
zuma's Avatar
Mike, remember your pleasure is worth every penny, Go for it, (just don't tell your wife) LOL
zuma is offline
post #6 of 6 (permalink) Old Jul 3rd, 02, 01:48 PM
I had the same problem with an old truck of mine...would squeal when wet out and had all the accesories on. I bought one of those solid-v belts...not sure what to call it. They don't have all the gaps on the inside...just solid material. Problem solved.
Dan-69rallysport is offline
