92 RS losing oil pressure when warm - Team Camaro Tech
post #1 of 7 (permalink) Old Aug 24th, 02, 06:00 PM Thread Starter
i have replaced the oil pumpand screen along with the distributor,coil,and its gear but still pressure zeros out when braking when engine is at normal temp
camaro877 is offline
post #2 of 7 (permalink) Old Aug 24th, 02, 06:49 PM
whats the oil pressure at, when cold? are you sure your not just low on oil?
Stock 67 327 RS
www.angelfire.com/ca7/goatjjcamarors/index.html
goatjj is offline
post #3 of 7 (permalink) Old Aug 25th, 02, 04:14 AM Thread Starter
the oil pressure cold is 25-30 and the level is correct any insight would be helpful.
post #4 of 7 (permalink) Old Aug 26th, 02, 03:17 PM
I'm a little late to help you on this one but I ALWAYS check bearings when pan is off. Might not be the problem but only adds 30 minutes to repair time and can catch a problem before catastrophic failure. Is this a high mileage engine? Have you tried heavier weight oil?
Georgia_Gearhead is offline
post #5 of 7 (permalink) Old Aug 26th, 02, 11:34 PM Thread Starter
yes it is a high mileage car and i use 5w30 max life by valvoline
post #6 of 7 (permalink) Old Aug 28th, 02, 03:53 AM
How thick can you make thtat oil?
68ragtop is offline
post #7 of 7 (permalink) Old Aug 28th, 02, 06:11 AM
change your oil to 20-50 for a v8 40 for a V6 and to either engine add 1 quart lucas oil stabilizer or even 2 quarts, but keep level at 5 quarts trust me it will help.
storman is offline
