ls1 in my 68 Camaro weird oil - Team Camaro Tech
post #1 of 10 (permalink) Old Jun 21st, 12, 05:22 PM Thread Starter
Apprentice
Let me start with letting everyone know i have been researching for days lol please forgive another water in my oil post. I recently rebuilt my engine from short block up. Now after driving it a few times it has been over heating, nothing crazy but overheating non the less. I was gonna replace the cam but when i began the tear down i discovered a few problems and have no idea where to head next.
Problems: oil has a green tint and is VERY then, not milky but very thin and smells sweet.
Dipstick is milky when checking oil.
Engine continues to loose coolant, i have refilled it after driving it and when i check it a few days later its low again. (maybe 2 glasses each time)
Engine over heats
Steps taken so far: coolant pressure test... holds pressure
Compression test all cylenders are within 10 PSI of each other.
Next thing i can think of is look at the head gaskets but i am afraid of that and dont wanna spend the money if i dont have to.
My68SSMistress is offline
post #2 of 10 (permalink) Old Jun 21st, 12, 08:25 PM
Re: ls1 in my 68 Camaro weird oil
If its not leaking out, its possible its burning it. I would think you would find the issue by either the collant psi check or compression check you performed. One other thing to consider is these motors seem to be a pain about getting the air out of the cooling system. I'm on my 4th LS1 swap & every one took a few running & then cooling overnight to get all the air out. Each time the coolant is low in the rad. It runs hot until all the air is out. When you say its overheating, is it pushing coolant into your overflow tank? How hot is it getting on the guage? Scott
69 RS LS3/T56
68 Firebird vert LS1/4L60E
67 RS LS2/T56
Z06vette is offline
post #3 of 10 (permalink) Old Jun 21st, 12, 08:28 PM
One test you can do is remove spark plugs after bringing engine up to temperature.
Now inject into a closed cylinder, meaning both valves closed, piston at TDC, and inject shop air into the cylinder.
Remove radiator cap and look for bubbles. Bubbles mean a broken head gasket or warped head when hot.
There is a reason the engine is losing coolant and collecting in the crankcase, as evidenced by milk on the dipstick.
The leak could be coming from the coolant ports-to-intake ports. Gasket not sealing, or maybe a warped cylinder head.
post #4 of 10 (permalink) Old Jun 22nd, 12, 07:06 AM Thread Starter
Apprentice
The engine got up to 210 maybe 220. I have been thinking about maybe there is air in the system. I took the valve covers off lastnight and found that rockers over cylinder 1357 were white from moisture in the oil. I have also pulled all of the oil and its not very thick at all, it will barely stay on a screw driver. There isnt any clots or junks but it is really dark and i only have around 100 miles since last oil change.
post #5 of 10 (permalink) Old Jun 22nd, 12, 04:01 PM
Do you get a sweet smell from the exhaust or steam when it's warmed up?
69 Pace Car and 69 Hard top
srode is offline
post #6 of 10 (permalink) Old Jun 22nd, 12, 05:07 PM
Josh
Cracked head. Seen more than a few recently. You already KNOW you are mixing coolant and oil from your original post, just take it out and have the heads mag'd, you'll probably find them cracked around the boss of the head bolts. At the very least you'll find the problem, even if the heads are not cracked
Grabbin2ndgear is offline
post #7 of 10 (permalink) Old Jun 22nd, 12, 06:01 PM
check compression/leakdown both hot and cold also pressure test the cooling system both ways before tearing into anything.
68 Camaro~LSx ~all motor
post #8 of 10 (permalink) Old Jun 24th, 12, 10:28 AM
Chris
I agree with this,accept you cant mag aluminum heads they have to be pressure tested.I work in a machine shop and we have seen LS heads cracked around the head bolt bosses,also could be a warped head and not sealing to the gasket good,did you use new head bolts?
CMQuickcoupe is offline
post #9 of 10 (permalink) Old Jun 28th, 12, 08:59 PM
Billy Morris
If the spark plugs have brown specks on them you are getting water in the cylinder.
Billy
morrisclassic is offline
post #10 of 10 (permalink) Old Jul 14th, 12, 07:47 PM
john
did you put sealent on your head bolts some times water leaks though head bolts they go though coolet jacket check them out
jgonzalez is offline
