Ignition - Team Camaro Tech
post #1 of 1 (permalink) Old Jun 21st, 12, 09:43 PM Thread Starter
Eric
Ignition
I have a '94 3.4 auto floor shift. I had my car diagnosed with a switch on the column being bad. They said there are 2 ignition switches, 1 that the key goes in and 1 on top of the column under the dash. It has a set of contacts on one side and a hole in the end and another hole for a rod that comes from the steering wheel. First off, what is the rod? And second, the hole in the rear of the module takes a cable set-up, what is that? and last... I'm an idiot for trying this myself! I disassembled the bottom of the dash to reach it, which only gave me about 2" of work space, At the bottom of the column there are 3 bolts that hold it to the floor, what would happen if I undo these bolts for more room? And the cable assembly has me stuck also, when I try to put it in the hole this small plunger inside keeps it from going in all the way. What the heck am I doing wrong?(besides trying this myself).
Eric Taylor is offline
Tags
cable, ignition problem, steering column
