New Brake System.. No Brakes? - Team Camaro Tech
post #1 of 3 (permalink) Old Aug 11th, 02, 01:19 AM Thread Starter
Marc
I just put in a new after market disc brake system in my 67 camaro along with a line lock/roll stop. I also have new rear brakes on my ford 9 inch. Everything is new, but the splitter. I bench bled the master cylinder and I have tried bleeding the brakes several times, but there are no brakes unless you pump them 6-8 times. Then they work. What might be the problem? Do I still have air in the system? If so, Any suggestions?
camaro man is offline
post #2 of 3 (permalink) Old Aug 11th, 02, 02:23 PM
Yep....air still there, and lot's of it. When you pump fluid, it compresses the air and finally they work. Try a vacuum bleeding system.
STEVE JACK
ConceptOne Pulleys and Brackets
Northern/Southern Rodder Magazine's "Jack'Stands" author and creator
Techical forum/links at www.inccn.net/techforum.htm
HOTRODSRJ is offline
post #3 of 3 (permalink) Old Aug 11th, 02, 02:58 PM
Check to make sure you installed the calipers on the correct side.The bleeder valve should be above the line to the caliper.
[This message has been edited by 67camss/rs (edited 08-12-2002).]
67camss/rs is offline
