backfire - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 12th, 01, 07:51 PM Thread Starter
when i completely and quickly let off the gas pedal after punching it, i get a backfire. if i SLOWLY let off the pedal there is NO backfire.
what is the probable cause for this?
thanks
zuerchers is offline
post #2 of 5 (permalink) Old Jun 13th, 01, 06:47 AM
You're probably running headers and big pipes, which allows enough oxygen to re-ignite exhaust gases. No problem though. First check your timing...it could be retarded, and needs to be advanced. Then check your air/fuel mix. You're probably rich (are the insides of your tailpipes dark or black?). If these two fixes don't cure the backfiring, you could be a candidate for a valve job. I'd get it fixed though...ignition in the exhaust system will shorten the life of your pipes. Good luck!
Sleepy-69 is offline
post #3 of 5 (permalink) Old Jun 13th, 01, 01:29 PM
Not to sure but if it has an air pump you may have a bad check valve....when they go bad it will backfire on decel.....gl man
Cly
Clyoatis is offline
post #4 of 5 (permalink) Old Jun 13th, 01, 01:39 PM Thread Starter
thanks guys.
post #5 of 5 (permalink) Old Jun 14th, 01, 09:30 PM
Also check for vacuum leaks...especially in the exhaust system.
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
travis is offline
