86 camaro - Team Camaro Tech
post #1 of 7 (permalink) Old Jan 9th, 01, 06:58 AM Thread Starter
My 86 Z28 sports coupe is turning but will not start. Just changed spark plugs and wires, there is a ticking coming from the carb. Some one please help need to fix asap....
MOLEY is offline
post #2 of 7 (permalink) Old Jan 9th, 01, 07:56 AM
You may need to rebuild your carb. Sounds a bit congested.
navajo is offline
post #3 of 7 (permalink) Old Jan 9th, 01, 11:30 AM
if you prime the carb will it start are you getting spark is the carb pumping fuel and does it tick when you turn the key onto the on position not cranking just turned on to the on position try priming the carb and see if it starts if it does then either the fuel pump is not working or the carb is messed up let me know you said that you changed your wires is it possable that you made a mistake putting them on you should check them good luck
James
James
james is offline
post #4 of 7 (permalink) Old Jan 9th, 01, 11:39 AM
well are you getting spark is the when you look into the carb and you pump the throtle do you see gas going in will it start if you prime the carb and does it tick when it is cranking or when it is just turned onto the on position and you said that you changed the wires is it possable that you made a mistake good look
James
james is offline
post #5 of 7 (permalink) Old Jan 10th, 01, 02:43 AM
James, Please use some punctuation, it is very hard to read your posts, Thanks.
Leo Paugh
MCC #017
www.clark.net/pub/chevelle/mcc.htm
There are no strangers here, only friends you haven't met.
chev64 is offline
post #6 of 7 (permalink) Old Jan 10th, 01, 09:28 AM
no problem i was in a real rush when i was typing that. but no problem chev64 sorry for that.
James
james is offline
post #7 of 7 (permalink) Old Jan 10th, 01, 12:42 PM
<BLOCKQUOTE>quote:</font><HR>Originally posted by MOLEY:
My 86 Z28 sports coupe is turning but will not start. Just changed spark plugs and wires, there is a ticking coming from the carb. Some one please help need to fix asap....<HR></BLOCKQUOTE>
the clicking you hear is the mc soleniod thats normal go back to basics is there spark and is there fuel being delivered
minisprint44 is offline
