engine backfires thru the carb - Team Camaro Tech
post #1 of 7 (permalink) Old Jul 4th, 12, 08:00 PM Thread Starter
Tony
Send a message via AIM to tony -Di
engine backfires thru the carb when i excelerate i removed the idle screws blew air into the openings , i cked the wiring at the coil dist ,its not consistant . 350 engine malory uilite dist mech advance, MSD . edilbrock carb . i was out most of the day and it was doing it a few times . and then it was good for a while and them it was doing it again if someone could give me a list of items to ck
thanks
Tony
tony -Di is offline
post #2 of 7 (permalink) Old Jul 5th, 12, 04:22 AM
Re: engine backfires thru the carb
Originally Posted by tony -Di View Post
i cked the wiring at the coil dist ,its not consistant . thanks Tony
What wire and the circuit the wire is in?
Sometimes backfire through carb is incorrect timing - too retarded, sticking intake valve.
post #3 of 7 (permalink) Old Jul 5th, 12, 07:30 AM
Michael
Happened to me aswell but it turned out to be a bent push rod ...derp...
But check timing usually its just that.
Chevmic is offline
post #4 of 7 (permalink) Old Jul 5th, 12, 12:20 PM
LB
I would start with easiest first: verify the distributor wires are on the right spark plugs. I've seen this issue even stump the seasoned mechanic.
The firing order is 1,8,4,3,6,5,7,2.
1,3,5,7 is on the left bank (driver side) and 2,4,6,8 is on the right bank. The distributor rotates clockwise, so find plug wire #1 and go from there.
TX-67 is offline
post #5 of 7 (permalink) Old Jul 5th, 12, 12:45 PM
DjD
DjD's Avatar
Back fire through the carb indicates an intake valve being open when a plug fires... If you don't have a couple plug wires swapped and your timing isn't all out of wack check your valve adjustment and from there start looking for a bent intake valve...
...Dennis
DjD is offline
post #6 of 7 (permalink) Old Jul 5th, 12, 04:26 PM Thread Starter
Tony
i will ck everything tomorrow thanks for the input
tony
tony -Di is offline
post #7 of 7 (permalink) Old Jul 6th, 12, 07:01 AM
Chuck
Can also be a lean backfire caused by a weak/failing accelator pump.
Chuck is offline
