pinging and hesitation - Team Camaro Tech
post #1 of 5 (permalink) Old May 3rd, 01, 05:01 PM Thread Starter
I have to figure this out quickly, the race is a week from friday. First let me tell you I am a mechanic, so this is a weird problem I haven't encountered before. My care pings and hesitates when I floor it at higher speeds, say 45 to 70 mph. I have checked everything I can think of and now wonder if the computer may be bad. The oxygen sensor, knock sensor, fuel pressure, air filter, timing, plugs, wires, injectors, everything. Please if you know help me.
jamesbern is offline
post #2 of 5 (permalink) Old May 3rd, 01, 05:55 PM
DjD
DjD's Avatar
What type of car? What engine?
...Dennis
'69 RS Convertible w/SS trim
'96 Z28SS #1679 of 2410
"The Club"
DjD is offline
post #3 of 5 (permalink) Old May 4th, 01, 05:06 PM Thread Starter
92 RS tbi
post #4 of 5 (permalink) Old May 5th, 01, 06:01 PM
David Pozzi
davidpozzi's Avatar
Check your vibration dampener for the ring slipping. Your timing may be off if it moved on you. It sounds like a timing problem.
Try running without the knock sensor disconnected, and try with the set timing pigtail unplugged and see if it acts differently.
If you had a bad plug wire, it might crossfire to an adjacent cylinder inside the distributor cap. Moisture inside the distributor cap would cause trouble too. Have you washed the engine lately?
Does it rev OK in neutral?
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
65 Lola T-70 Chev 350
Can Am Vintage Racer
[This message has been edited by davidpozzi (edited 05-05-2001).]
davidpozzi is offline
post #5 of 5 (permalink) Old May 6th, 01, 12:37 PM Thread Starter
I have thought it was a timing problem from the start, but I have checked the harmonic balncer and it is in excellent shape. I had a bad knock sensor and I replaced, that helped a little. With the timing plug disconnected it loses its advance and doesn't run well, but it doesn't ping either. I replaced the wires and I have them spaced as far apart from each other as possible. It is most likely the computer in my mind. Does anyone know how tto check them? I appreciate you ideas and help so please keep them coming.
