Got spark but no fire off.... - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 10th, 03, 11:03 AM Thread Starter
Last night i started it up and it ran for about 30 secs then went dead. There was a fuel leak in the fuel pump outlet fitting...so i fixed that. This morning it wont do anything, just turns over without any sign of starting, i pulled the #3 plug to make sure it was getting spark, and now i dont know what to do.
385
MSD Pro billet distributor
MSD Blaster 2 coil
MSD 6AL box
Accel Extreme 9000 wires
any ideas?
|72 Nova|385ci|AFR 195s|Vic JR|Holley 770 Avenger|CC 284XE|MSD 6AL|MSD Pro-Billet|3" X-pipe|Dynomax Ultra-Flo's|TH-350|Eaton posi|3.73 gears|15x8 Rod-Lites|275/60R/15 Nitto 555R|
atldc is offline
post #2 of 3 (permalink) Old Mar 10th, 03, 01:09 PM
When I have these problems, I go back to the basics.
You need three things present in order to get an engine to run....fuel...compression...and correct ignition timing/spark.
I ususally pick the one that seems to be the most likely culprit and start there and work my way down the list.
Good luck!
BPOS is offline
post #3 of 3 (permalink) Old Mar 10th, 03, 03:59 PM
When you pulled #3 did you see sparks or not?
-dnult
dnult is offline
