Torque Specs '69 M-22 Trans - Team Camaro Tech
post #1 of 5 (permalink) Old Sep 14th, 02, 11:57 AM Thread Starter
Does anybody have a shop manual that has the torque specs for the flywheel, bellhousing and trans bolts. I am trying to put it in right now. Thanks.
clm69z28 is offline
post #2 of 5 (permalink) Old Sep 14th, 02, 12:34 PM
Flywheel: 47-55 (60 max) ft lbs w/ red loctite
Bell housing: 20-30 ft lbs
Trans bolts: 45-60 ft lbs
Pressure plate: 28-32 ft lbs w/ red loctite
kurt6325 is offline
post #3 of 5 (permalink) Old Sep 14th, 02, 01:53 PM
Bill
Just as a matter of information, I do not think GM ever mentioned any type of thread locking compound in any of thier torque specs from that era.
Bill Koustenis
Owner
Advanced Automotive Machine
Waldorf Md
BillK is offline
post #4 of 5 (permalink) Old Sep 14th, 02, 02:29 PM
I think your right BillK, but I'm still going to use it. Makes me sleep better.
kurt6325 is offline
post #5 of 5 (permalink) Old Sep 14th, 02, 02:38 PM
Rick
For what it's worth, I used ARP flywheel bolts and their assembly lube. They said 75 ft-lbs using assembly lube and 125 using 30 wt motor oil. I understand the factory spec is 65. The lubricant will affect yor torque settings.
Rick Dorion
69 RS Conv,355,Autogear M22,4.10's and I don't worry about stone chips ( yet ).
RickD is offline
