92 Flame Out - Team Camaro Tech
post #1 of 9 (permalink) Old Aug 5th, 03, 03:50 AM Thread Starter
Have 92 RS six banger, runs great except after long hi speed fwy trips, dies @ off ramp stop;then starts right up no problem: any ideas?
Henry Sigel is offline
post #2 of 9 (permalink) Old Aug 5th, 03, 06:58 AM
Fuel Pump weak, or maybe a partially plugged Fuel Filter?
Mark Canning
1969 Indy Pace Car
350/300HP RPO Z11
Mark C is offline
post #3 of 9 (permalink) Old Aug 5th, 03, 07:35 AM
ZZ_430's Avatar
Sounds like the TCC solenoid.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #4 of 9 (permalink) Old Aug 5th, 03, 08:09 AM
maybe egr is hanging open to long...plug vacum source to it and give it a try..
gunny is offline
post #5 of 9 (permalink) Old Aug 5th, 03, 12:51 PM
Or brake pedal switch that disengages the TCC.
-dnult
dnult is offline
post #6 of 9 (permalink) Old Aug 6th, 03, 02:53 AM Thread Starter
2 questions How does TCC Sol. cause enginr to stall? Looks like an extensive repair, help on what a reputable Xmission shoop would charge?
post #7 of 9 (permalink) Old Aug 6th, 03, 03:06 AM
Send a message via AIM to Spames
If the solenoid isn't letting the torque convertor dis-engage, it will stall the engine... It'd be like coming to a stop in a manual trans car without pushing in the clutch.
You could try to disconnect the solenoid to see if it is the problem. Should be a 4-prong plug that goes into the transmission. Disconnecting the solenoid will not allow the torque convertor to lock.
Spames is offline
post #8 of 9 (permalink) Old Aug 7th, 03, 03:10 AM Thread Starter
Thanks for the info! What are the ramifications of operating too long / far without solenoid connected?
post #9 of 9 (permalink) Old Aug 7th, 03, 03:51 AM
Higher than normal transmission temperatures that could damage the transmission, however, I ran my 700 for 3 years without a lock-up convertor, and noticed no problems. I'd say you'd be fine to disconnect it, run it out on the highway for a short test, and see if you still have the problem.
Spames is offline
